All nethserver works fine so far but already several times th mail app on my Phone hangs becaus of some corrupt item. Ussualy regarding agenda.
Errors as reported by z-push-error.log:
LoopDetection->ProcessLoopDetectionPreviousConnectionFailed(): Command ‘Sync’ at 04/05/2017 19:00:39 with pid ‘1637’ terminated unexpectedly or is still running.
04/05/2017 19:01:18 [ 1636] [ERROR] [xxxx@xxxxx.xx] Please check your logs for this PID and errors like PHP-Fatals or Apache segmentation faults and report your results to the Z-Push dev team.
04/05/2017 19:01:25 [ 1636] [FATAL] [xxxx@xxxxx.xx] Fatal error: /usr/share/webtop/z-push/include/iCalendar.php:49 - require_once(): Failed opening required ‘XMLElement.php’ (include_path=’.:/usr/share/pear:/usr/share/php’) (64)
In your z-push, find the “include” folder: rename iCalendar.php in iCalendar.php.old.
This is precisely the file that generates the error in the log that you indicated, carried by awl in z-push, without having carried all the other php employees.
Then copy from the awl package, the contents of “inc” (there are various php: iCalendar.php, XMLElement.php …) inside z-push’s “include”.
made the changes as per your suggestion. Previous error disappeared but now my Phone gives a authentication error. So I deleted the account on my android Phone en made a new one but this didn’t solve it.
Could there be a relation with OTP security in webtop?
Hi, after deleting your account on the phone, you may also want to delete all the z-push data from the syncrhonization settings panel in Webtop.
Here you will be able to list the known devices and delete their sync data.
Then try creating the account from scratch.
