Yum update problem on 6.8
i have made the upgrade…
now if i make an “yum update” it say:
 yum update
Loaded plugins: changelog, fastestmirror, nethserver_events, presto, security
Setting up Update Process
 * centos-base: mirror.ratiokontakt.de
Excluding mirror: centos.copahost.com
 * centos-updates: centosmirror.netcup.net
 * nethserver-base: mirror2.nethserver.org
 * nethserver-updates: mirror2.nethserver.org
http://mirror.centos.org/centos/6/SCL/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
Trying other mirror.
To address this issue please refer to the below knowledge base article
https://access.redhat.com/articles/1320623
If above article doesn't help to resolve this issue please open a ticket with Red Hat Support.
Error: Cannot retrieve repository metadata (repomd.xml) for repository: scl. Please verify its path and try again
anyone know how to solve this?
It looks like the SCL/x86_64/repodata/ folders have not been created or rsynced on the mirror yet.
My guess its just a case of waiting for a couple of hours for the relevant folders to be synced to the mirror and then the issue should resolve itself. Only time will tell.
The Problem persist… :frowning:
What happens if you run yum clean all and yum update?
Same problem…
Please, disable the SCL repo.
Edit: the command is: yum remove centos-release-SCL-6-5.el6.centos.x86_64
