YUM repository configuration issue after removing subscription
Fixed but not completly, I have to repeat this every day but when I come back in the morning the next day I get this message yet again :
failure: repodata/repomd.xml from sb-base: [Errno 256] No more mirrors to try. https://m1.nethserver.com/stable/7.4.1708/base/x86_64/repodata/repomd.xml: [Errno 14] HTTPS Error 403 - Forbidden
The install/update may have failed due to metadata caching issues. Please clean the cache by clicking the button below and retry the install/update operation.
Did you updated to 7.5?
Instruction for 7.5 are different: http://docs.nethserver.org/en/v7/subscription.html#removing-a-subscription
No, Dashboard says I’m still on 7.4 : NethServer release 7.4.1708 (Final)
I do have Stephdl Repository on this one. But I think that is disabled by default?
Just update to 7.5 and apply the linked instructions.
I’d like to try that, but I’m afraid I can’t seem to find the proper way to upgrade my installation.
Tried https://www.cyberciti.biz/linux-news/rhel-7-5-released-how-to-upgrade-7-4-to-7-5/ but that didn’t seem to do anything.
Did you add some template-custom to lock the release number?
find /etc/e-smith/templates-custom/ -type f
Please show also (replace secrets with XXX, if they’re present)
 config show subscription
[root@mynethserver ~]# find /etc/e-smith/templates-custom/ -type f
[root@mynethserver ~]# config show subscription
subscription=configuration
xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx=
AlertsAutoUpdates=enabled
AlertsUrl=https://my.nethserver.com/api/machine/
ApiUrl=https://my.nethserver.com/api/
InventoryUrl=https://my.nethserver.com/api/machine/inventories/store/
NsRelease=7.4.1708
PricingUrl=https://my.nethserver.com/?action=newServer
Secret=
SystemId=xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
Despite @giacomo’s command your SystemId is still set :thinking:
Please repeat the procedure, and make sure SystemId is an empty string.
I suggest to update to 7.5 thereafter:
 yum update
Oh yes right, my mistake, I replaced ‘’ SystemId ‘’ in giacomo’s with my system’s SystemId :grimacing:
Did it again, just copy and paste this time :innocent:
    NsRelease=7.4.1708
    Secret=
    SystemId=
Ok you still have this minor glitch. You can run this command
config delprop subscription THE_STRING_HIDDEN_BY_Xs
Or just re-create the whole subscription key
config delete subscription
/etc/e-smith/events/actions/initialize-default-databases
Yes, did all that, and looks a lot better but still now upgrade to 7.5 :
[root@mynethserver ~]# config delprop subscription xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
    NsRelease=7.4.1708
    Secret=
    SystemId=
[root@mynethserver ~]# yum update
 * base: centos.cu.be
 * epel: mirror.kinamo.be
 * extras: centos.cu.be
 * nethforge: mirror.nordest.systems
 * nethserver-base: mirror.nordest.systems
 * nethserver-updates: mirror.nordest.systems
 * updates: centos.cu.be
No packages marked for update
Should I reboot or send some signal event thing? :innocent:
The command
yum clean all
Should be enough. If not please send
yum repolist -v
 * base: mirror.kinamo.be
 * extras: mirror.kinamo.be
 * nethforge: server.liftingtrade.hu
 * nethserver-base: server.liftingtrade.hu
 * nethserver-updates: server.liftingtrade.hu
 * updates: mirror.kinamo.be
[root@mynethserver ~]# cat /etc/os-release
NAME="CentOS Linux"
VERSION="7 (Core)"
ID="centos"
ID_LIKE="rhel fedora"
VERSION_ID="7"
PRETTY_NAME="CentOS Linux 7 (Core)"
ANSI_COLOR="0;31"
CPE_NAME="cpe:/o:centos:centos:7"
HOME_URL="https://www.centos.org/"
BUG_REPORT_URL="https://bugs.centos.org/"
CENTOS_MANTISBT_PROJECT="CentOS-7"
CENTOS_MANTISBT_PROJECT_VERSION="7"
REDHAT_SUPPORT_PRODUCT="centos"
REDHAT_SUPPORT_PRODUCT_VERSION="7"
[root@mynethserver ~]# yum repolist -v
Loading "changelog" plugin
Loading "fastestmirror" plugin
Loading "nethserver_events" plugin
Config time: 0.020
Yum version: 3.4.3
Setting up Package Sacks
pkgsack time: 0.021
Repo-id      : base/7/x86_64
Repo-name    : CentOS-7 - Base
Repo-revision: 1525378614
Repo-updated : Thu May  3 22:17:37 2018
Repo-pkgs    : 9,911
Repo-size    : 8.2 G
Repo-mirrors : http://mirrorlist.centos.org/?release=7&arch=x86_64&repo=os&infra=stock
Repo-baseurl : http://mirror.kinamo.be/centos/7.5.1804/os/x86_64/ (9 more)
Repo-expire  : 21,600 second(s) (last: Wed Jun 20 04:33:24 2018)
  Filter     : read-only:present
Repo-filename: /etc/yum.repos.d/CentOS-Base.repo
Repo-id      : centos-sclo-rh/x86_64
Repo-name    : CentOS-7 - SCLo rh
Repo-revision: 1528277584
Repo-updated : Wed Jun  6 11:35:10 2018
Repo-pkgs    : 7,514
Repo-size    : 6.7 G
Repo-baseurl : http://mirror.centos.org/centos/7/sclo/x86_64/rh/
Repo-filename: /etc/yum.repos.d/CentOS-SCLo-scl-rh.repo
Repo-id      : centos-sclo-sclo/x86_64
Repo-name    : CentOS-7 - SCLo sclo
Repo-revision: 1528277362
Repo-updated : Wed Jun  6 11:29:27 2018
Repo-pkgs    : 755
Repo-size    : 236 M
Repo-baseurl : http://mirror.centos.org/centos/7/sclo/x86_64/sclo/
Repo-filename: /etc/yum.repos.d/CentOS-SCLo-scl.repo
Repo-id      : epel/x86_64
Repo-name    : Extra Packages for Enterprise Linux 7 - x86_64
Repo-revision: 1529417147
Repo-updated : Tue Jun 19 16:15:29 2018
Repo-pkgs    : 12,585
Repo-size    : 13 G
Repo-metalink: https://mirrors.fedoraproject.org/metalink?repo=epel-7&arch=x86_64
  Updated    : Tue Jun 19 16:15:29 2018
Repo-baseurl : http://mirror.kinamo.be/epel/7/x86_64/ (86 more)
Repo-filename: /etc/yum.repos.d/epel.repo
Repo-id      : extras/7/x86_64
Repo-name    : CentOS-7 - Extras
Repo-revision: 1528918839
Repo-updated : Wed Jun 13 21:42:33 2018
Repo-pkgs    : 313
Repo-size    : 556 M
Repo-mirrors : http://mirrorlist.centos.org/?release=7&arch=x86_64&repo=extras&infra=stock
Repo-baseurl : http://mirror.kinamo.be/centos/7.5.1804/extras/x86_64/ (9 more)
Repo-id      : nethforge/7/x86_64
Repo-name    : NethForge 7
Repo-revision: 1526481335
Repo-updated : Wed May 16 16:35:36 2018
Repo-pkgs    : 22
Repo-size    : 26 M
Repo-mirrors : http://mirrorlist.nethserver.org/7/nethserver?release=7&repo=nethforge&arch=x86_64
Repo-baseurl : http://server.liftingtrade.hu/nethserver/7.5.1804/nethforge/x86_64/ (14 more)
Repo-filename: /etc/yum.repos.d/NethForge.repo
Repo-id      : nethserver-base/7/x86_64
Repo-name    : NethServer-7 - Base
Repo-revision: 1509031675
Repo-updated : Thu Oct 26 17:27:59 2017
Repo-pkgs    : 250
Repo-size    : 830 M
Repo-mirrors : http://mirrorlist.nethserver.org/?release=7&repo=base&arch=x86_64&nsrelease=
Repo-baseurl : http://server.liftingtrade.hu/nethserver/7.4.1708/base/x86_64/ (14 more)
Repo-filename: /etc/yum.repos.d/NethServer.repo
Repo-id      : nethserver-updates/7/x86_64
Repo-name    : NethServer-7 - Updates
Repo-revision: 1529396842
Repo-updated : Tue Jun 19 10:27:36 2018
Repo-pkgs    : 435
Repo-size    : 1.7 G
Repo-mirrors : http://mirrorlist.nethserver.org/?release=7&repo=updates&arch=x86_64&nsrelease=
Repo-baseurl : http://server.liftingtrade.hu/nethserver/7.4.1708/updates/x86_64/ (14 more)
Repo-id      : updates/7/x86_64
Repo-name    : CentOS-7 - Updates
Repo-revision: 1529098471
Repo-updated : Fri Jun 15 23:46:07 2018
Repo-pkgs    : 695
Repo-size    : 2.5 G
Repo-mirrors : http://mirrorlist.centos.org/?release=7&arch=x86_64&repo=updates&infra=stock
Repo-baseurl : http://mirror.kinamo.be/centos/7.5.1804/updates/x86_64/ (9 more)
repolist: 32,480
It’s really strange: you still have an URL to 7.4… It is not consistent with the mirrorlist response here! Please test it by yourself
 curl 'http://mirrorlist.nethserver.org/?release=7&repo=updates&arch=x86_64&nsrelease='
The output should contain 7.5.1804
Did you edit /etc/yum.repos.d/NethServer.repo ? Please attach it here!
Yes, It does :innocent:
[root@mynethserver ~]# curl 'http://mirrorlist.nethserver.org/?release=7&repo=updates&arch=x86_64&nsrelease='
http://mirror.nethserver.org/nethserver/7.5.1804/updates/x86_64/
http://mirror1.nethserver.org/nethserver/7.5.1804/updates/x86_64/
http://mirror2.nethserver.org/nethserver/7.5.1804/updates/x86_64/
https://mirror.nethesis.it/nethserver/7.5.1804/updates/x86_64/
http://nethserver.de-labrusse.fr/7.5.1804/updates/x86_64/
http://mirror.framassa.org/nethserver/7.5.1804/updates/x86_64/
http://mirror.nordest.systems/nethserver/7.5.1804/updates/x86_64/
https://mirror.alpix.eu/nethserver/7.5.1804/updates/x86_64/
http://mrmarkuz.goip.de/mirror/nethserver/7.5.1804/updates/x86_64/
http://mirror.pcxlan.es/nethserver/7.5.1804/updates/x86_64/
https://markusneuberger.at/mirror/nethserver/7.5.1804/updates/x86_64/
http://buck.goip.de/nethserver/7.5.1804/updates/x86_64/
http://nethserver.globalcortex.net/mirror/nethserver/7.5.1804/updates/x86_64/
http://server.liftingtrade.hu/nethserver/7.5.1804/updates/x86_64/
http://ketrax.eu/nethserver/7.5.1804/updates/x86_64/
[root@mynethserver ~]# cat /etc/yum.repos.d/NethServer.repo
# nethserver.org YUM repositories configuration
[nethserver-base]
name=NethServer-$releasever - Base
mirrorlist=http://mirrorlist.nethserver.org/?release=$releasever&repo=base&arch=$basearch&nsrelease=$nsrelease
#baseurl=http://mirror.nethserver.org/nethserver/$releasever/base/$basearch/
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-NethServer-$releasever
enabled=1
enablegroups=0
[nethserver-updates]
name=NethServer-$releasever - Updates
mirrorlist=http://mirrorlist.nethserver.org/?release=$releasever&repo=updates&arch=$basearch&nsrelease=$nsrelease
#baseurl=http://mirror.nethserver.org/nethserver/$releasever/updates/$basearch/
enabled=1
enablegroups=1
[nethserver-testing]
name=NethServer-$releasever - Testing
mirrorlist=http://mirrorlist.nethserver.org/?release=$releasever&repo=testing&arch=$basearch&nsrelease=$nsrelease
#baseurl=http://mirror.nethserver.org/nethserver/$releasever/testing/$basearch/
enabled=0
enablegroups=0
Guess it’s already on 7.5 after all, but why does it say 7.4 on the dashboard :confused:
I don’t know why it’s still pointing to repositories of 7.4. Do you have any web proxy between NethServer and Internet?
Please try again:
yum clean all
rm -rf /var/cache/yum/
yum --setopt=http_caching=none update
Yes now dashboard says it’s updated :
[root@mynethserver ~]# yum clean all
Cleaning repos: base centos-sclo-rh centos-sclo-sclo epel extras nethforge nethserver-base nethserver-updates updates
Cleaning up everything
Maybe you want: rm -rf /var/cache/yum, to also free up space taken by orphaned data from disabled or removed repos
Cleaning up list of fastest mirrors
[root@mynethserver ~]# rm -rf /var/cache/yum/
[root@mynethserver ~]# yum --setopt=http_caching=none update
Determining fastest mirrors
epel/x86_64/metalink        |  31 kB  00:00:00
 * base: mirror.unix-solutions.be
 * epel: fedora.cu.be
 * extras: mirror.unix-solutions.be
 * nethforge: mirror.framassa.org
 * nethserver-base: mirror.framassa.org
 * nethserver-updates: mirror.framassa.org
 * updates: mirror.unix-solutions.be
base        | 3.6 kB  00:00:00
centos-sclo-rh        | 3.0 kB  00:00:00
centos-sclo-sclo        | 2.9 kB  00:00:00
epel        | 3.2 kB  00:00:00
extras        | 3.4 kB  00:00:00
nethforge        | 4.0 kB  00:00:00
nethserver-base        | 2.9 kB  00:00:00
nethserver-updates        | 4.1 kB  00:00:00
updates        | 3.4 kB  00:00:00
(1/14): base/7/x86_64/group_gz        | 166 kB  00:00:00
(2/14): epel/x86_64/group_gz        |  88 kB  00:00:00
(3/14): centos-sclo-sclo/x86_64/primary_db        | 281 kB  00:00:00
(4/14): extras/7/x86_64/primary_db        | 149 kB  00:00:00
(5/14): nethforge/7/x86_64/group_gz        | 1.1 kB  00:00:00
(6/14): nethforge/7/x86_64/primary_db        |  15 kB  00:00:00
(7/14): base/7/x86_64/primary_db        | 5.9 MB  00:00:01
(8/14): nethserver-base/7/x86_64/primary_db        | 296 kB  00:00:00
(9/14): nethserver-updates/7/x86_64/group_gz        |  20 kB  00:00:00
(10/14): nethserver-updates/7/x86_64/primary_db        |  41 kB  00:00:00
(11/14): epel/x86_64/updateinfo        | 933 kB  00:00:02
(12/14): updates/7/x86_64/primary_db        | 2.7 MB  00:00:00
(13/14): epel/x86_64/primary        | 3.5 MB  00:00:02
(14/14): centos-sclo-rh/x86_64/primary_db        | 3.5 MB  00:00:04
epel        12585/12585
Resolving Dependencies
--> Running transaction check
---> Package nethserver-firewall-base.noarch 0:3.3.2-1.ns7 will be updated
---> Package nethserver-firewall-base.noarch 0:3.4.1-1.ns7 will be an update
--> Processing Dependency: firehol for package: nethserver-firewall-base-3.4.1-1.ns7.noarch
---> Package nethserver-httpd.noarch 0:3.2.1-1.ns7 will be updated
---> Package nethserver-httpd.noarch 0:3.2.4-1.ns7 will be an update
---> Package nethserver-httpd-admin.noarch 0:2.2.1-1.ns7 will be updated
---> Package nethserver-httpd-admin.noarch 0:2.3.1-1.ns7 will be an update
---> Package nethserver-httpd-virtualhosts.noarch 0:3.2.1-1.ns7 will be updated
---> Package nethserver-httpd-virtualhosts.noarch 0:3.2.4-1.ns7 will be an update
---> Package nethserver-lang-en.noarch 0:1.2.10-1.ns7 will be updated
---> Package nethserver-lang-en.noarch 0:1.2.11-1.ns7 will be an update
---> Package nethserver-nethforge-release.noarch 0:7-0.3.ns7 will be updated
---> Package nethserver-nethforge-release.noarch 0:7-2.ns7 will be an update
---> Package nethserver-release.noarch 0:7-5.ns7 will be updated
---> Package nethserver-release.noarch 0:7-8.ns7 will be an update
---> Package firehol.noarch 0:3.1.5-1.el7.centos will be installed
--> Processing Dependency: iptables-ipv6 for package: firehol-3.1.5-1.el7.centos.noarch
---> Package iptables-services.x86_64 0:1.4.21-24.1.el7_5 will be installed
Dependencies Resolved
 Package                                                        Arch                                    Version                                              Repository                                           Size
Updating:
 nethserver-firewall-base                                       noarch                                  3.4.1-1.ns7                                          nethserver-updates                                   96 k
 nethserver-httpd                                               noarch                                  3.2.4-1.ns7                                          nethserver-base                                      52 k
 nethserver-httpd-admin                                         noarch                                  2.3.1-1.ns7                                          nethserver-base                                     1.6 M
 nethserver-httpd-virtualhosts                                  noarch                                  3.2.4-1.ns7                                          nethserver-base                                      40 k
 nethserver-lang-en                                             noarch                                  1.2.11-1.ns7                                         nethserver-base                                      23 k
 nethserver-nethforge-release                                   noarch                                  7-2.ns7                                              nethserver-base                                     6.7 k
 nethserver-release                                             noarch                                  7-8.ns7                                              nethserver-base                                      24 k
Installing for dependencies:
 firehol                                                        noarch                                  3.1.5-1.el7.centos                                   nethserver-base                                     1.3 M
 iptables-services                                              x86_64                                  1.4.21-24.1.el7_5                                    updates                                              51 k
Transaction Summary
Install             ( 2 Dependent packages)
Upgrade  7 Packages
Total download size: 3.1 M
Is this ok [y/d/N]: y
Downloading packages:
No Presto metadata available for nethserver-base
nethserver-updates/7/x86_64/prestodelta        | 1.5 kB  00:00:00
(1/9): iptables-services-1.4.21-24.1.el7_5.x86_64.rpm        |  51 kB  00:00:00
(2/9): nethserver-firewall-base-3.4.1-1.ns7.noarch.rpm        |  96 kB  00:00:00
(3/9): nethserver-httpd-3.2.4-1.ns7.noarch.rpm        |  52 kB  00:00:00
(4/9): nethserver-nethforge-release-7-2.ns7.noarch.rpm        | 6.7 kB  00:00:00
(5/9): nethserver-release-7-8.ns7.noarch.rpm        |  24 kB  00:00:00
nethserver-httpd-virtualhosts- FAILED                                                        44% [====================================-                                              ]  0.0 B/s | 1.4 MB  --:--:-- ETA
http://mirror1.nethserver.org/nethserver/7.5.1804/base/x86_64/Packages/nethserver-httpd-virtualhosts-3.2.4-1.ns7.noarch.rpm: [Errno 14] HTTP Error 404 - Not Found                   ]  0.0 B/s | 1.4 MB  --:--:-- ETA
Trying other mirror.
To address this issue please refer to the below wiki article
https://wiki.centos.org/yum-errors
If above article doesn't help to resolve this issue please use https://bugs.centos.org/.
(6/9): firehol-3.1.5-1.el7.centos.noarch.rpm        | 1.3 MB  00:00:00
(7/9): nethserver-httpd-virtualhosts-3.2.4-1.ns7.noarch.rpm        |  40 kB  00:00:00
(8/9): nethserver-lang-en-1.2.11-1.ns7.noarch.rpm        |  23 kB  00:00:00
(9/9): nethserver-httpd-admin-2.3.1-1.ns7.noarch.rpm        | 1.6 MB  00:00:00
Total        3.7 MB/s | 3.1 MB  00:00:00
Running transaction test
Transaction test succeeded
Running transaction
  Installing : iptables-services-1.4.21-24.1.el7_5.x86_64        1/16
  Installing : firehol-3.1.5-1.el7.centos.noarch        2/16
  Updating   : nethserver-lang-en-1.2.11-1.ns7.noarch        3/16
  Updating   : nethserver-httpd-3.2.4-1.ns7.noarch        4/16
  Updating   : nethserver-release-7-8.ns7.noarch        5/16
  Updating   : nethserver-nethforge-release-7-2.ns7.noarch        6/16
  Updating   : nethserver-httpd-virtualhosts-3.2.4-1.ns7.noarch        7/16
  Updating   : nethserver-httpd-admin-2.3.1-1.ns7.noarch        8/16
  Updating   : nethserver-firewall-base-3.4.1-1.ns7.noarch        9/16
  Cleanup    : nethserver-httpd-admin-2.2.1-1.ns7.noarch        10/16
  Cleanup    : nethserver-httpd-virtualhosts-3.2.1-1.ns7.noarch        11/16
  Cleanup    : nethserver-nethforge-release-7-0.3.ns7.noarch        12/16
  Cleanup    : nethserver-release-7-5.ns7.noarch        13/16
  Cleanup    : nethserver-httpd-3.2.1-1.ns7.noarch        14/16
  Cleanup    : nethserver-lang-en-1.2.10-1.ns7.noarch        15/16
  Cleanup    : nethserver-firewall-base-3.3.2-1.ns7.noarch        16/16
  Verifying  : nethserver-release-7-8.ns7.noarch        1/16
  Verifying  : nethserver-firewall-base-3.4.1-1.ns7.noarch        2/16
  Verifying  : nethserver-nethforge-release-7-2.ns7.noarch        3/16
  Verifying  : nethserver-httpd-virtualhosts-3.2.4-1.ns7.noarch        4/16
  Verifying  : nethserver-httpd-3.2.4-1.ns7.noarch        5/16
  Verifying  : firehol-3.1.5-1.el7.centos.noarch        6/16
  Verifying  : nethserver-lang-en-1.2.11-1.ns7.noarch        7/16
  Verifying  : iptables-services-1.4.21-24.1.el7_5.x86_64        8/16
  Verifying  : nethserver-httpd-admin-2.3.1-1.ns7.noarch        9/16
  Verifying  : nethserver-httpd-virtualhosts-3.2.1-1.ns7.noarch        10/16
  Verifying  : nethserver-lang-en-1.2.10-1.ns7.noarch        11/16
  Verifying  : nethserver-httpd-3.2.1-1.ns7.noarch        12/16
  Verifying  : nethserver-release-7-5.ns7.noarch        13/16
  Verifying  : nethserver-firewall-base-3.3.2-1.ns7.noarch        14/16
  Verifying  : nethserver-nethforge-release-7-0.3.ns7.noarch        15/16
  Verifying  : nethserver-httpd-admin-2.2.1-1.ns7.noarch        16/16
Dependency Installed:
  firehol.noarch 0:3.1.5-1.el7.centos        iptables-services.x86_64 0:1.4.21-24.1.el7_5
Updated:
  nethserver-firewall-base.noarch 0:3.4.1-1.ns7       nethserver-httpd.noarch 0:3.2.4-1.ns7               nethserver-httpd-admin.noarch 0:2.3.1-1.ns7       nethserver-httpd-virtualhosts.noarch 0:3.2.4-1.ns7
  nethserver-lang-en.noarch 0:1.2.11-1.ns7            nethserver-nethforge-release.noarch 0:7-2.ns7       nethserver-release.noarch 0:7-8.ns7
Complete!
Release - System version - NethServer release 7.5.1804 (final)
Kernel release 3.10.0-862.3.3.el7.x86_64
Thank you very much ! :smile:
