davidep:
yum repolist -v
[root@nethserver /]# yum repolist -v
Loading "auto-update-debuginfo" plugin
Loading "changelog" plugin
Loading "fastestmirror" plugin
Loading "nethserver_events" plugin
Config time: 0.026
Yum version: 3.4.3
rpmdb time: 0.000
Found 7 installed debuginfo package(s)
Determining fastest mirrors
sb-base | 3.6 kB 00:00
sb-centos-sclo-rh | 3.0 kB 00:00
sb-centos-sclo-sclo | 2.9 kB 00:00
sb-epel | 3.2 kB 00:00
sb-extras | 3.4 kB 00:00
sb-nethserver-base | 2.9 kB 00:00
sb-nethserver-updates | 4.1 kB 00:00
sb-updates | 3.4 kB 00:00
(1/12): sb-epel/x86_64/group_gz | 88 kB 00:01
(2/12): sb-base/x86_64/group_gz | 166 kB 00:01
(3/12): sb-centos-sclo-sclo/x86_64/primary_db | 205 kB 00:01
(4/12): sb-epel/x86_64/updateinfo | 932 kB 00:01
(5/12): sb-centos-sclo-rh/x86_64/primary_db | 3.5 MB 00:03
(6/12): sb-nethserver-base/x86_64/primary_db | 294 kB 00:00
(7/12): sb-epel/x86_64/primary | 3.5 MB 00:02
(8/12): sb-nethserver-updates/x86_64/group_gz | 20 kB 00:00
(9/12): sb-nethserver-updates/x86_64/primary_db | 39 kB 00:00
(10/12): sb-extras/x86_64/primary_db | 147 kB 00:03
(11/12): sb-updates/x86_64/primary_db | 2.0 MB 00:01
(12/12): sb-base/x86_64/primary_db | 5.9 MB 00:06
sb-epel 12585/12585
Setting up Package Sacks
pkgsack time: 0.019
Repo-id : sb-base/x86_64
Repo-name : Stable mirror: CentOS Base 7
Repo-revision: 1525378614
Repo-updated : Thu May 3 15:17:37 2018
Repo-pkgs : 9,911
Repo-size : 8.2 G
Repo-mirrors : https://mirrorlist.nethserver.com/?repo=base&arch=x86_64&nsversion=7.5.1804&usetier=$YUM0
Repo-baseurl : https://m1.nethserver.com/stable/7.5.1804/base/x86_64/
Repo-expire : 7,200 second(s) (last: Tue Jun 19 15:53:42 2018)
Filter : read-only:present
Repo-filename: /etc/yum.repos.d/subscription.repo
Repo-id : sb-centos-sclo-rh/x86_64
Repo-name : Stable mirror: SCLo rh 7
Repo-revision: 1527163724
Repo-updated : Thu May 24 07:10:49 2018
Repo-pkgs : 7,467
Repo-size : 6.6 G
Repo-mirrors : https://mirrorlist.nethserver.com/?repo=centos-sclo-rh&arch=x86_64&nsversion=7.5.1804&usetier=$YUM0
Repo-baseurl : https://m1.nethserver.com/stable/7.5.1804/centos-sclo-rh/x86_64/
Repo-id : sb-centos-sclo-sclo/x86_64
Repo-name : Stable mirror: SCLo sclo 7
Repo-revision: 1526296152
Repo-updated : Mon May 14 06:09:15 2018
Repo-pkgs : 521
Repo-size : 109 M
Repo-mirrors : https://mirrorlist.nethserver.com/?repo=centos-sclo-sclo&arch=x86_64&nsversion=7.5.1804&usetier=$YUM0
Repo-baseurl : https://m1.nethserver.com/stable/7.5.1804/centos-sclo-sclo/x86_64/
Repo-expire : 7,200 second(s) (last: Tue Jun 19 15:53:43 2018)
Repo-id : sb-epel/x86_64
Repo-name : Stable mirror: EPEL 7
Repo-revision: 1528116085
Repo-updated : Mon Jun 4 08:01:23 2018
Repo-pkgs : 12,585
Repo-size : 13 G
Repo-mirrors : https://mirrorlist.nethserver.com/?repo=epel&arch=x86_64&nsversion=7.5.1804&usetier=$YUM0
Repo-baseurl : https://m1.nethserver.com/stable/7.5.1804/epel/x86_64/
Repo-id : sb-extras/x86_64
Repo-name : Stable mirror: CentOS Extras 7
Repo-revision: 1527610607
Repo-updated : Tue May 29 11:18:56 2018
Repo-pkgs : 305
Repo-size : 545 M
Repo-mirrors : https://mirrorlist.nethserver.com/?repo=extras&arch=x86_64&nsversion=7.5.1804&usetier=$YUM0
Repo-baseurl : https://m1.nethserver.com/stable/7.5.1804/extras/x86_64/
Repo-id : sb-nethserver-base/x86_64
Repo-name : Stable mirror: NethServer Base 7
Repo-revision: 1527497768
Repo-updated : Mon May 28 03:56:18 2018
Repo-pkgs : 283
Repo-size : 1.0 G
Repo-mirrors : https://mirrorlist.nethserver.com/?repo=nethserver-base&arch=x86_64&nsversion=7.5.1804&usetier=$YUM0
Repo-baseurl : https://m1.nethserver.com/stable/7.5.1804/nethserver-base/x86_64/
Repo-expire : 7,200 second(s) (last: Tue Jun 19 15:53:44 2018)
Repo-id : sb-nethserver-updates/x86_64
Repo-name : Stable mirror: NethServer Updates 7
Repo-revision: 1528116727
Repo-updated : Mon Jun 4 07:52:09 2018
Repo-pkgs : 14
Repo-size : 15 M
Repo-mirrors : https://mirrorlist.nethserver.com/?repo=nethserver-updates&arch=x86_64&nsversion=7.5.1804&usetier=$YUM0
Repo-baseurl : https://m1.nethserver.com/stable/7.5.1804/nethserver-updates/x86_64/
Repo-id : sb-updates/x86_64
Repo-name : Stable mirror: CentOS Updates 7
Repo-revision: 1527864102
Repo-updated : Fri Jun 1 09:46:22 2018
Repo-pkgs : 654
Repo-size : 2.3 G
Repo-mirrors : https://mirrorlist.nethserver.com/?repo=updates&arch=x86_64&nsversion=7.5.1804&usetier=$YUM0
Repo-baseurl : https://m1.nethserver.com/stable/7.5.1804/updates/x86_64/
davidep:
yum check-update
rpm -qf /etc/yum.repos.d/*
[root@nethserver /]# rpm -qf /etc/yum.repos.d/*
centos-release-7-5.1804.el7.centos.2.x86_64
centos-release-scl-2-2.el7.centos.noarch
centos-release-scl-rh-2-2.el7.centos.noarch
epel-release-7-11.noarch
nethserver-mrmarkuz-0.0.1-2.ns7.noarch
file /etc/yum.repos.d/msprod.repo is not owned by any package
file /etc/yum.repos.d/mssql-server.repo is not owned by any package
nethserver-nethforge-release-7-2.ns7.noarch
nethserver-release-7-8.ns7.noarch
ocsinventory-release-7-4.el7.ocs.noarch
remi-release-7.5-1.el7.remi.noarch
nethserver-stephdl-1.0.6-1.ns7.sdl.noarch
file /etc/yum.repos.d/subscription.repo is not owned by any package
[root@nethserver /]# [root@nethserver /]# yum repolist -v
sb-extras -bash: [root@nethserver: command not found
| 3.4 kB 00:00
(9/12): sb-nethserver-updates/x86_64/primary_db | 39 kB 00:0[
Now is working (after the RE-subscription, of course) I saw librabbitq 08 for update not the last kernel. thanks @davidep for Your help.
