Yum: Failed to check for updates on ads.avion.lan
NethServer Version: NethServer release 7.5.1804 (final)
Module: Software Center
I got this mail at the morning:
Failed to check for updates with the following error message:
Failed to build transaction: nethserver-backup-config-2.2.0-1.ns7.noarch requires perl-Proc-ProcessTable
nethserver-backup-config-2.2.0-1.ns7.noarch requires perl(Proc::ProcessTable)
I login and in the UI, the first and 2nd time I got this message:
Resolving RPM dependencies
The install/update may have failed due to metadata caching issues. Please clean the cache by clicking the button below and retry the install/update operation.
[CLEAR YUM CACHE]
I click “CLEAR YUM CACHE”, it shows more packages, and the same message.
Trying a 3rd time… but this time I’ll not click on [DOWNLOAD AND INSTALL] until post here, and I’ll wait a little, maybe the servers are resting :wink:
Regards
Packages showed the 1st time:
Name Version Release
nethserver-backup-config 2.2.0 1.ns7
nethserver-backup-data 1.4.0 1.ns7
nethserver-base 3.4.3 1.ns7
nethserver-duc 1.4.4 1.ns7
nethserver-httpd-admin 2.3.4 1.ns7
Packages at 2nd time:
bind-libs 9.9.4 61.el7_5.1
bind-libs-lite 9.9.4 61.el7_5.1
bind-license 9.9.4 61.el7_5.1
bind-utils 9.9.4 61.el7_5.1
Now 3rd time:
perl-Proc-ProcessTable packages comes from EPEL.
Could you please try to update from command line and see if EPEL is working?
I works!
# yum update
  • ce-base: mirror.rackspace.com
  • ce-extras: mirror.rackspace.com
  • ce-updates: mirror.rackspace.com
  • epel: mirror.sjc02.svwh.net
  • nethforge: mirror.nethserver.org
  • nethserver-base: mirror.nethserver.org
  • nethserver-updates: mirror.nethserver.org
    Resolving Dependencies
    — Running transaction check
    ---- Package certbot.noarch 0:0.24.0-1.el7 will be updated
    ---- Package certbot.noarch 0:0.26.1-2.el7 will be an update
    ---- Package collectd.x86_64 0:5.8.0-3.el7 will be updated
    ---- Package collectd.x86_64 0:5.8.0-4.el7 will be an update
    ---- Package collectd-ping.x86_64 0:5.8.0-3.el7 will be updated
    ---- Package collectd-ping.x86_64 0:5.8.0-4.el7 will be an update
    ---- Package collectd-rrdtool.x86_64 0:5.8.0-3.el7 will be updated
    ---- Package collectd-rrdtool.x86_64 0:5.8.0-4.el7 will be an update
    ---- Package nethserver-backup-config.noarch 0:2.1.0-1.ns7 will be updated
    ---- Package nethserver-backup-config.noarch 0:2.2.0-1.ns7 will be an update
    — Processing Dependency: perl-Proc-ProcessTable for package: nethserver-backup-config-2.2.0-1.ns7.noarch
    — Processing Dependency: perl(Proc::ProcessTable) for package: nethserver-backup-config-2.2.0-1.ns7.noarch
    ---- Package nethserver-backup-data.noarch 0:1.3.5-1.ns7 will be updated
    ---- Package nethserver-backup-data.noarch 0:1.4.0-1.ns7 will be an update
    — Processing Dependency: sshpass for package: nethserver-backup-data-1.4.0-1.ns7.noarch
    — Processing Dependency: restic for package: nethserver-backup-data-1.4.0-1.ns7.noarch
    ---- Package nethserver-base.noarch 0:3.4.2-1.ns7 will be updated
    ---- Package nethserver-base.noarch 0:3.4.3-1.ns7 will be an update
    ---- Package nethserver-duc.noarch 0:1.4.3-1.ns7 will be updated
    ---- Package nethserver-duc.noarch 0:1.4.4-1.ns7 will be an update
    ---- Package nethserver-httpd-admin.noarch 0:2.3.3-1.ns7 will be updated
    ---- Package nethserver-httpd-admin.noarch 0:2.3.4-1.ns7 will be an update
    ---- Package nethserver-stephdl.noarch 0:1.0.6-1.ns7.sdl will be updated
    ---- Package nethserver-stephdl.noarch 0:1.0.7-1.ns7.sdl will be an update
    ---- Package python2-acme.noarch 0:0.24.0-1.el7 will be updated
    ---- Package python2-acme.noarch 0:0.26.1-1.el7 will be an update
    — Processing Dependency: python-requests-toolbelt for package: python2-acme-0.26.1-1.el7.noarch
    ---- Package python2-certbot.noarch 0:0.24.0-1.el7 will be updated
    ---- Package python2-certbot.noarch 0:0.26.1-2.el7 will be an update
    ---- Package perl-Proc-ProcessTable.x86_64 0:0.48-1.el7 will be installed
    ---- Package python-requests-toolbelt.noarch 0:0.8.0-1.el7 will be installed
    ---- Package restic.x86_64 0:0.9.1-1.ns7 will be installed
    ---- Package sshpass.x86_64 0:1.06-2.el7 will be installed
    ---- Finished Dependency Resolution
Dependencies Resolved
Package… Arch…Version… Repository… Size
Updating:
certbot… noarch… 0.26.1-2.el7… epel… 21 k
collectd… x86_64… 5.8.0-4.el7… epel…713 k
collectd-ping… x86_64… 5.8.0-4.el7… epel… 23 k
collectd-rrdtool… x86_64… 5.8.0-4.el7… epel… 28 k
nethserver-backup-config… noarch… 2.2.0-1.ns7… nethserver-updates… 48 k
nethserver-backup-data…noarch… 1.4.0-1.ns7… nethserver-updates… 65 k
nethserver-base… noarch… 3.4.3-1.ns7… nethserver-updates… 243 k
nethserver-duc…noarch… 1.4.4-1.ns7… nethserver-updates… 78 k
nethserver-httpd-admin…noarch… 2.3.4-1.ns7… nethserver-updates… 1.6 M
nethserver-stephdl…noarch… 1.0.7-1.ns7.sdl… stephdl… 20 k
python2-acme… noarch… 0.26.1-1.el7… epel…140 k
python2-certbot… noarch… 0.26.1-2.el7… epel…519 k
Installing for dependencies:
perl-Proc-ProcessTable…x86_64… 0.48-1.el7…epel… 47 k
python-requests-toolbelt… noarch… 0.8.0-1.el7… epel… 77 k
restic…x86_64… 0.9.1-1.ns7… nethserver-updates… 3.3 M
sshpass… x86_64… 1.06-2.el7…ce-extras…21 k
Transaction Summary
Install… ( 4 Dependent packages)
Upgrade 12 Packages
Total download size: 6.9 M
Is this ok [y/d/N]: y
Downloading packages:
No Presto metadata available for stephdl
(1/2): epel/x86_64/prestodelta… | 835 B 00:00:00…
(2/2): nethserver-updates/7/x86_64/prestodelta… | 13 kB 00:00:00…
Delta RPMs reduced 126 k of updates to 30 k (75% saved)
(1/16): certbot-0.26.1-2.el7.noarch.rpm… | 21 kB 00:00:00…
(2/16): collectd-rrdtool-5.8.0-4.el7.x86_64.rpm… | 28 kB 00:00:00…
(3/16): nethserver-backup-config-2.1.0-1.ns7_2.2.0-1.ns7.noarch.drpm…| 21 kB 00:00:00…
(4/16): nethserver-duc-1.4.3-1.ns7_1.4.4-1.ns7.noarch.drpm… | 8.8 kB 00:00:00…
(5/16): collectd-ping-5.8.0-4.el7.x86_64.rpm…| 23 kB 00:00:01…
(6/16): nethserver-stephdl-1.0.7-1.ns7.sdl.noarch.rpm… | 20 kB 00:00:01…
(7/16): nethserver-backup-data-1.4.0-1.ns7.noarch.rpm… | 65 kB 00:00:02…
(8/16): perl-Proc-ProcessTable-0.48-1.el7.x86_64.rpm…| 47 kB 00:00:00…
(9/16): python-requests-toolbelt-0.8.0-1.el7.noarch.rpm… | 77 kB 00:00:01…
(10/16): nethserver-base-3.4.3-1.ns7.noarch.rpm… | 243 kB 00:00:05…
(11/16): python2-acme-0.26.1-1.el7.noarch.rpm… | 140 kB 00:00:02…
(12/16): sshpass-1.06-2.el7.x86_64.rpm… | 21 kB 00:00:01…
(13/16): collectd-5.8.0-4.el7.x86_64.rpm…| 713 kB 00:00:10…
(14/16): python2-certbot-0.26.1-2.el7.noarch.rpm…| 519 kB 00:00:06…
(15/16): nethserver-httpd-admin-2.3.4-1.ns7.noarch.rpm… | 1.6 MB 00:00:21…
(16/16): restic-0.9.1-1.ns7.x86_64.rpm… | 3.3 MB 00:00:28…
Total… 202 kB/s | 6.8 MB 00:00:34…
Running transaction test
Transaction test succeeded
Running transaction
Updating : nethserver-base-3.4.3-1.ns7.noarch… 1/28
Updating : collectd-5.8.0-4.el7.x86_64…2/28
Installing : perl-Proc-ProcessTable-0.48-1.el7.x86_64… 3/28
Updating : nethserver-backup-config-2.2.0-1.ns7.noarch…4/28
Installing : restic-0.9.1-1.ns7.x86_64… 5/28
Installing : sshpass-1.06-2.el7.x86_64… 6/28
Installing : python-requests-toolbelt-0.8.0-1.el7.noarch…7/28
Updating : python2-acme-0.26.1-1.el7.noarch… 8/28
Updating : python2-certbot-0.26.1-2.el7.noarch…9/28
Updating : certbot-0.26.1-2.el7.noarch… 10/28
Updating : nethserver-backup-data-1.4.0-1.ns7.noarch… 11/28
Updating : collectd-ping-5.8.0-4.el7.x86_64… 12/28
Updating : collectd-rrdtool-5.8.0-4.el7.x86_64… 13/28
Updating : nethserver-httpd-admin-2.3.4-1.ns7.noarch… 14/28
Updating : nethserver-duc-1.4.4-1.ns7.noarch… 15/28
Updating : nethserver-stephdl-1.0.7-1.ns7.sdl.noarch… 16/28
Cleanup…: nethserver-duc-1.4.3-1.ns7.noarch… 17/28
Cleanup…: certbot-0.24.0-1.el7.noarch… 18/28
Cleanup…: python2-certbot-0.24.0-1.el7.noarch… 19/28
Cleanup…: nethserver-backup-data-1.3.5-1.ns7.noarch… 20/28
Cleanup…: nethserver-backup-config-2.1.0-1.ns7.noarch… 21/28
Cleanup…: nethserver-httpd-admin-2.3.3-1.ns7.noarch… 22/28
Cleanup…: collectd-rrdtool-5.8.0-3.el7.x86_64… 23/28
Cleanup…: collectd-ping-5.8.0-3.el7.x86_64… 24/28
Cleanup…: nethserver-base-3.4.2-1.ns7.noarch…25/28
Cleanup…: python2-acme-0.24.0-1.el7.noarch… 26/28
Cleanup…: nethserver-stephdl-1.0.6-1.ns7.sdl.noarch… 27/28
Cleanup…: collectd-5.8.0-3.el7.x86_64… 28/28
Verifying : python2-acme-0.26.1-1.el7.noarch… 1/28
Verifying : python-requests-toolbelt-0.8.0-1.el7.noarch…2/28
Verifying : sshpass-1.06-2.el7.x86_64… 3/28
Verifying : collectd-ping-5.8.0-4.el7.x86_64… 4/28
Verifying : collectd-5.8.0-4.el7.x86_64…5/28
Verifying : collectd-rrdtool-5.8.0-4.el7.x86_64…6/28
Verifying : python2-certbot-0.26.1-2.el7.noarch…7/28
Verifying : nethserver-httpd-admin-2.3.4-1.ns7.noarch… 8/28
Verifying : nethserver-stephdl-1.0.7-1.ns7.sdl.noarch… 9/28
Verifying : nethserver-backup-data-1.4.0-1.ns7.noarch… 10/28
Verifying : nethserver-base-3.4.3-1.ns7.noarch…11/28
Verifying : restic-0.9.1-1.ns7.x86_64… 12/28
Verifying : nethserver-backup-config-2.2.0-1.ns7.noarch… 13/28
Verifying : certbot-0.26.1-2.el7.noarch… 14/28
Verifying : nethserver-duc-1.4.4-1.ns7.noarch… 15/28
Verifying : perl-Proc-ProcessTable-0.48-1.el7.x86_64… 16/28
Verifying : python2-certbot-0.24.0-1.el7.noarch… 17/28
Verifying : nethserver-stephdl-1.0.6-1.ns7.sdl.noarch… 18/28
Verifying : nethserver-backup-data-1.3.5-1.ns7.noarch… 19/28
Verifying : collectd-rrdtool-5.8.0-3.el7.x86_64… 20/28
Verifying : collectd-5.8.0-3.el7.x86_64… 21/28
Verifying : collectd-ping-5.8.0-3.el7.x86_64… 22/28
Verifying : nethserver-httpd-admin-2.3.3-1.ns7.noarch… 23/28
Verifying : python2-acme-0.24.0-1.el7.noarch… 24/28
Verifying : certbot-0.24.0-1.el7.noarch… 25/28
Verifying : nethserver-backup-config-2.1.0-1.ns7.noarch… 26/28
Verifying : nethserver-duc-1.4.3-1.ns7.noarch… 27/28
Verifying : nethserver-base-3.4.2-1.ns7.noarch…28/28
Dependency Installed:
perl-Proc-ProcessTable.x86_64 0:0.48-1.el7…python-requests-toolbelt.noarch 0:0.8.0-1.el7…restic.x86_64 0:0.9.1-1.ns7
sshpass.x86_64 0:1.06-2.el7…
Updated:
certbot.noarch 0:0.26.1-2.el7… collectd.x86_64 0:5.8.0-4.el7…
collectd-ping.x86_64 0:5.8.0-4.el7… collectd-rrdtool.x86_64 0:5.8.0-4.el7…
nethserver-backup-config.noarch 0:2.2.0-1.ns7… nethserver-backup-data.noarch 0:1.4.0-1.ns7…
nethserver-base.noarch 0:3.4.3-1.ns7…nethserver-duc.noarch 0:1.4.4-1.ns7…
nethserver-httpd-admin.noarch 0:2.3.4-1.ns7… nethserver-stephdl.noarch 0:1.0.7-1.ns7.sdl…
python2-acme.noarch 0:0.26.1-1.el7… python2-certbot.noarch 0:0.26.1-2.el7…
Complete!
I can confirm exactly the same situation, and by doing “yum update” it updates fine. Can send the logs if necessary.
