Confession upfront: My daily driver is MS Windows but work on a linux-desktop, most virtual machines, at least once per week; this out of the way like to share my experience.
I switch distro’s quite regularly where Debian is my goto-falback choice. At the time of writing using CentOS 8 Stream (promised to revisit it)
Because I switch often, always using xfce as desktop because:
all generic distro’s have it
it is quite light wight: easy to connect to over VNC or RDP and runs on arm.
I know it very well
have my favorite theme in my .dot_file.zip ; its to my liking in no-time.
If the install is on real hardware I always prepare for a multi-boot system, do this om my arm systems too. (as said, switch distribution often) This can be a bit cumbersome with the installers, end the end it never failed. This also means to plan partitioning, especially if a GPT participation is not possible and toy are bound to MBR. (Switched a my x86_64 hardware installs to uefi)
This partitioning scheme includes a partition for data, which gets mounted in all installs.
Your intention is for most administrating Nethserver and your question implies you did not work a lot with linux desktops…
If this is the case you maybe best of with a RPM, YUM/DNF based distro like Fedora or Mageia.
grtz, Mark
BTW one of the most loved peaches of software by me:
M$ vscode (cannot work without it )
Even if you’ve never driven a Mercedes Benz before in your life, only “other” car brands, you’ll find the steering wheel where you expect it, in front of you. There’s no joystick, like in a plane.
The gas pedal? Same as every other car…
Except the fuel efficiency and weight! This one is sleek!
Windows for me too.
Plus putty, several browsers (Firefox is my daily browser), VMware Player (hack and slash testbench for client and test installations), some time tracking tool, WinSCP, text editor better than Windows’ notepad, way for create howtos, checklists, end users- infocards, setup-walkthrough (screen recording, office automation). A nice backup tool (Veeam for Windows). A cloud storage account (third tier of docs backup). A good antivirus (sometimes is not “that” cheap).
And a quite big NAS (for a single person) for backups and copies. With a lot of users, restrictive ACLs, a paper with all the passwords of the NAS and of keychains.
By the way, time to control if the fattening rebuild of the customer NAS is ended.
You can build rpm and have always the last rpm version. It is a 6 months release but you can miss one release because each version is maintained 12 months
For the desktop I would go to gnome, a old habit
Virtualization you have the choice, VirtualBox (easy but with drawbacks) or kvm and virt-manager
If you have some money I would change the spinning disk to a ssd
