Wordpress 404 not found on links
Greetings everyone i am having an issue with speratic 404 not found on some of my sites… but no all…
I have checked the .htaccess file for the site in question kc9zhv.com
Here is what it is…
# BEGIN WordPress
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteBase /
RewriteRule ^index\.php$ - [L]
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule . /index.php [L]
</IfModule>
# END WordPress
So… Kinda lost as to what to do…
Their is multiple sites on one machine here my httpd.conf looks kinda like this…
File location
/etc/httpd/conf/httpd.conf
[root@webserver conf]# cat httpd.conf
# Please read the developer’s guide, which is available
# at https://dev.nethesis.it/projects/nethserver/wiki/NethServer
# original work from http://www.contribs.org/development/
# Copyright © 2013 Nethesis S.r.l.
# http://www.nethesis.it - support@nethesis.it
# Dynamic Shared Object (DSO) Support
# To be able to use the functionality of a module which was built as a DSO you
# have to place corresponding `LoadModule' lines at this location so the
# directives contained in it are actually available _before_ they are used.
# Statically compiled modules (those listed by `httpd -l') do not need
# to be loaded here.
# Example:
# LoadModule foo_module modules/mod_foo.so
LoadModule auth_basic_module modules/mod_auth_basic.so
LoadModule auth_digest_module modules/mod_auth_digest.so
LoadModule authn_file_module modules/mod_authn_file.so
LoadModule authn_alias_module modules/mod_authn_alias.so
LoadModule authn_anon_module modules/mod_authn_anon.so
LoadModule authn_dbm_module modules/mod_authn_dbm.so
LoadModule authn_default_module modules/mod_authn_default.so
LoadModule authz_host_module modules/mod_authz_host.so
LoadModule authz_user_module modules/mod_authz_user.so
LoadModule authz_owner_module modules/mod_authz_owner.so
LoadModule authz_groupfile_module modules/mod_authz_groupfile.so
LoadModule authz_dbm_module modules/mod_authz_dbm.so
LoadModule authz_default_module modules/mod_authz_default.so
LoadModule ldap_module modules/mod_ldap.so
LoadModule authnz_ldap_module modules/mod_authnz_ldap.so
LoadModule include_module modules/mod_include.so
LoadModule log_config_module modules/mod_log_config.so
LoadModule logio_module modules/mod_logio.so
LoadModule env_module modules/mod_env.so
LoadModule ext_filter_module modules/mod_ext_filter.so
LoadModule mime_magic_module modules/mod_mime_magic.so
LoadModule expires_module modules/mod_expires.so
LoadModule deflate_module modules/mod_deflate.so
LoadModule headers_module modules/mod_headers.so
LoadModule usertrack_module modules/mod_usertrack.so
LoadModule setenvif_module modules/mod_setenvif.so
LoadModule mime_module modules/mod_mime.so
LoadModule dav_module modules/mod_dav.so
LoadModule status_module modules/mod_status.so
LoadModule autoindex_module modules/mod_autoindex.so
LoadModule info_module modules/mod_info.so
LoadModule dav_fs_module modules/mod_dav_fs.so
LoadModule vhost_alias_module modules/mod_vhost_alias.so
LoadModule negotiation_module modules/mod_negotiation.so
LoadModule dir_module modules/mod_dir.so
LoadModule actions_module modules/mod_actions.so
LoadModule speling_module modules/mod_speling.so
LoadModule userdir_module modules/mod_userdir.so
LoadModule alias_module modules/mod_alias.so
LoadModule substitute_module modules/mod_substitute.so
LoadModule rewrite_module modules/mod_rewrite.so
LoadModule proxy_module modules/mod_proxy.so
LoadModule proxy_balancer_module modules/mod_proxy_balancer.so
LoadModule proxy_ftp_module modules/mod_proxy_ftp.so
LoadModule proxy_http_module modules/mod_proxy_http.so
LoadModule proxy_ajp_module modules/mod_proxy_ajp.so
LoadModule proxy_connect_module modules/mod_proxy_connect.so
LoadModule cache_module modules/mod_cache.so
LoadModule suexec_module modules/mod_suexec.so
LoadModule disk_cache_module modules/mod_disk_cache.so
LoadModule cgi_module modules/mod_cgi.so
LoadModule version_module modules/mod_version.so
# 30base
### Section 1: Global Environment
ServerRoot "/etc/httpd"
PidFile run/httpd.pid
Timeout 60
KeepAlive Off
MaxKeepAliveRequests 100
KeepAliveTimeout 15
<IfModule prefork.c>
StartServers       20
MinSpareServers    10
MaxSpareServers   50
ServerLimit      256
MaxClients       256
MaxRequestsPerChild  4000
</IfModule>
<IfModule worker.c>
StartServers         10
MaxClients         300
MinSpareThreads     25
MaxSpareThreads     75
ThreadsPerChild     25
MaxRequestsPerChild  0
</IfModule>
Listen 80
Include conf.d/*.conf
Include nethserver.d/*.conf
User apache
Group apache
### Section 2: 'Main' server configuration
ServerAdmin webmaster@webserver.lorentedford.com
ServerName webserver.lorentedford.com:80
UseCanonicalName Off
DocumentRoot /var/www/html
<Directory />
    Options FollowSymLinks
    AllowOverride None
</Directory>
<Directory "/var/www/">
    Options Indexes FollowSymLinks
    AllowOverride None
    Order allow,deny
    Allow from all
</Directory>
<IfModule mod_userdir.c>
    UserDir disabled
</IfModule>
DirectoryIndex index.html index.html.var
AccessFileName .htaccess
<Files ~ "^\.ht">
    Order allow,deny
    Deny from all
    Satisfy All
</Files>
TypesConfig /etc/mime.types
DefaultType text/plain
<IfModule mod_mime_magic.c>
    MIMEMagicFile conf/magic
</IfModule>
HostnameLookups Off
ErrorLog logs/error_log
LogLevel warn
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %b" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
CustomLog logs/access_log combined
ServerSignature Off
# Aliases
Alias /icons/ "/var/www"
<Directory "/var/www/icons">
    Options Indexes MultiViews FollowSymLinks
    AllowOverride None
    Order allow,deny
    Allow from all
</Directory>
# WebDAV module configuration section.
<IfModule mod_dav_fs.c>
    # Location of the WebDAV lock database.
    DAVLockDB /var/lib/dav/lockdb
</IfModule>
ScriptAlias /cgi-bin/ "/var/www/cgi-bin/"
<Directory "/var/www/cgi-bin">
    AllowOverride None
    Options None
    Order allow,deny
    Allow from all
</Directory>
IndexOptions FancyIndexing VersionSort NameWidth=* HTMLTable Charset=UTF-8
# File indexes
AddIconByEncoding (CMP,/icons/compressed.gif) x-compress x-gzip
AddIconByType (TXT,/icons/text.gif) text/*
AddIconByType (IMG,/icons/image2.gif) image/*
AddIconByType (SND,/icons/sound2.gif) audio/*
AddIconByType (VID,/icons/movie.gif) video/*
AddIcon /icons/binary.gif .bin .exe
AddIcon /icons/binhex.gif .hqx
AddIcon /icons/tar.gif .tar
AddIcon /icons/world2.gif .wrl .wrl.gz .vrml .vrm .iv
AddIcon /icons/compressed.gif .Z .z .tgz .gz .zip
AddIcon /icons/a.gif .ps .ai .eps
AddIcon /icons/layout.gif .html .shtml .htm .pdf
AddIcon /icons/text.gif .txt
AddIcon /icons/c.gif .c
AddIcon /icons/p.gif .pl .py
AddIcon /icons/f.gif .for
AddIcon /icons/dvi.gif .dvi
AddIcon /icons/uuencoded.gif .uu
AddIcon /icons/script.gif .conf .sh .shar .csh .ksh .tcl
AddIcon /icons/tex.gif .tex
AddIcon /icons/bomb.gif core
AddIcon /icons/back.gif ..
AddIcon /icons/hand.right.gif README
AddIcon /icons/folder.gif ^^DIRECTORY^^
AddIcon /icons/blank.gif ^^BLANKICON^^
DefaultIcon /icons/unknown.gif
ReadmeName README.html
HeaderName HEADER.html
IndexIgnore .??* *~ *# HEADER* README* RCS CVS *,v *,t
# Languages
AddLanguage ca .ca
AddLanguage cs .cz .cs
AddLanguage da .dk
AddLanguage de .de
AddLanguage el .el
AddLanguage en .en
AddLanguage eo .eo
AddLanguage es .es
AddLanguage et .et
AddLanguage fr .fr
AddLanguage he .he
AddLanguage hr .hr
AddLanguage it .it
AddLanguage ja .ja
AddLanguage ko .ko
AddLanguage ltz .ltz
AddLanguage nl .nl
AddLanguage nn .nn
AddLanguage no .no
AddLanguage pl .po
AddLanguage pt .pt
AddLanguage pt-BR .pt-br
AddLanguage ru .ru
AddLanguage sv .sv
AddLanguage zh-CN .zh-cn
AddLanguage zh-TW .zh-tw
LanguagePriority en ca cs da de el eo es et fr he hr it ja ko ltz nl nn no pl pt pt-BR ru sv zh-CN zh-TW
ForceLanguagePriority Prefer Fallback
# Charset
AddDefaultCharset UTF-8
# File types
AddType application/x-compress .Z
AddType application/x-gzip .gz .tgz
AddType application/x-x509-ca-cert .crt
AddType application/x-pkcs7-crl    .crl
# Type handlers
AddHandler type-map var
# SSI type
AddType text/html .shtml
AddOutputFilter INCLUDES .shtml
# Errors
Alias /error/ "/var/www/error/"
<IfModule mod_negotiation.c>
<IfModule mod_include.c>
    <Directory "/var/www/error">
        AllowOverride None
        Options IncludesNoExec
        AddOutputFilter Includes html
        Order allow,deny
        Allow from all
        LanguagePriority en es de fr
    </Directory>
</IfModule>
</IfModule>
BrowserMatch "Mozilla/2" nokeepalive
BrowserMatch "MSIE 4\.0b2;" nokeepalive downgrade-1.0 force-response-1.0
BrowserMatch "RealPlayer 4\.0" force-response-1.0
BrowserMatch "Java/1\.0" force-response-1.0
BrowserMatch "JDK/1\.0" force-response-1.0
BrowserMatch "Microsoft Data Access Internet Publishing Provider" redirect-carefully
BrowserMatch "MS FrontPage" redirect-carefully
BrowserMatch "^WebDrive" redirect-carefully
BrowserMatch "^WebDAVFS/1.[0123]" redirect-carefully
BrowserMatch "^gnome-vfs/1.0" redirect-carefully
BrowserMatch "^XML Spy" redirect-carefully
BrowserMatch "^Dreamweaver-WebDAV-SCM1" redirect-carefully
# Virtual hosts
NameVirtualHost *:80
NameVirtualHost *:443
Include nethserver.d/*.vhost
Here are some other sites i have that seem to be working at the moment…
http://lorentedford.com/
http://voipham.com/
http://ilhamradio.org/ <— This site is under heavy construction at the moment…
Sites that have not yet been fixed or setup since my crash…
http://newwavesucks.com/
http://ltcraft.net/
http://kc9zhr.com/
I hope this helps out… But Really confused why one site is giving my so much grief… I wonder what would happen if i reinstalled wordpress in that directory… I don’t want things to explode…
Sorry for the late response, I hope @stephdl @drakuel @fasttech @Foa @dnutan @Sebastian @clinton may lend a hand here
The problem could be in htaccess try to replace
BEGIN WordPress
RewriteEngine On RewriteBase / RewriteRule ^index\.php$ - [L] RewriteCond %{REQUEST_FILENAME} !-f RewriteCond %{REQUEST_FILENAME} !-d RewriteRule . /index.php [L]
END WordPress
With
BEGIN WordPress
Options +FollowSymLinks -MultiViews
RewriteEngine On
RewriteBase /
RewriteRule ^index.php$ - [L]
END WordPress
Or check here:
@Sebastian, I think you hit it on the head.
The How to was the only thing I could think of.
Ok so none of the above seemed to work after reboot since we are dealing with other issues as well including the Nethserver not understanding what my default gateway is etc… I have had to do this special script to run after reboot… Here is what i came up with
crontab -e
@reboot /network.sh
Here is an example of what my script looks like
#!/bin/sh
sleep 30s
ifconfig eth1 10.10.10.158 netmask 255.255.255.255
sleep 2s
route add 192.168.1.254 dev eth1
route add default gw 192.168.1.254 eth1
sleep 2s
service httpd stop
cp -f /root/httpdbackup /etc/httpd/conf/httpd.conf
chmod 555 /etc/httpd/conf/httpd.conf
sleep 1s
service httpd start
All above are example of how my ip structure is… My default gateway is completely separate from my ip as show above i know sounds kinda crazy but is common in OVH… We have not been able to successfully set our ip using your control panel for some reason…
Above is an example script only… We are still testing it…
If anyone knows how to properly do the above ip in nethserver that would be great I would much rather fix the issue than to patch it on reboot… I am going to start a new support ticket on this with different title…
For some reason I was not able to get the same results i did copy this into each of my wordpress .htaccess files…
In httpd.conf
DirectoryIndex
there isn’t index.php
It could be a problem ?
Could you give me a db networks show screen ?!.
Sorry for the late reply i have been very busy with some local server transitions here at the house… Thanks for pointing out the index.php in httpd.conf I will have a look at it…
Now…
When i typed db networks show screen i got nothing…
I am confused at what you were asking… If you wish i can in private message kinda explain with greater detail of my ip configurations if thats what you wish to know…
