In the last couple of days I have had to restore a full backup of nethserver on my server (due to HDD failure).
As stated in a earlier post, I am using Wireless NIC to connect to a router / the Internet.
After the restoration on a new HDD, the WLAN connection was working, then I attempted a upgrade of this installation and afterwards the NIC failed to connect to the WLAN / router.
As far as I can see the ifup-wlan0 and wpa_supplicant.conf file has not been altered due to the upgrade -
The wpa_supplicant.conf contains the following:
ctrl_interface=/var/run/wpa_supplicant
ctrl_interface_group=wheel
network={
ssid="ssid-name"
scan_ssid=1
key_mgmt=WPA-PSK
psk=“ssid-password”
and the ifcfg-wlan0 contains:
DEVICE=wlan0
IPV6INIT=no
GATEWAY=192.168.0.1
HWADDR="MAC-Address"
IPADDR=192.168.0.2
NETMASK=255.255.255.0
NM_CONTOLLED=no
ONBOOT=yes
ESSID="ssid-name"
WPA=yes
USERCTRL=no
MODE=managed
Now, after restarting the wpa_supplicant service, I get the following error:
Starting wpa_supplicant: /etc/wpa_supplicant/wpa_supplicant.conf, -iwlan0, ieee80211 phy0: rt2800usb_fill_rxdone: Error - Bad frame size 13634, forcing to 0
ieee80211 phy0: rt2x00lib_rxdone: Error - Wrong frame size 0 max 3840
I can ping the local NIC (192.168.0.2) but not the router (192.168.0.1)
Like I stated above, before the upgrade this NIC was working OK, after the upgrade this NIC fails to connect to the router.
