Hi I’m on NethServer release 7.6.1810
if I do a
yum clean all
then
yum update
my yum list updates show
[root@nethserver1 ~]# yum list updates
Updated Packages
mono-core.x86_64 6.8.0-1.el7 epel
mono-data.x86_64 6.8.0-1.el7 epel
mono-data-oracle.x86_64 6.8.0-1.el7 epel
mono-data-sqlite.x86_64 6.8.0-1.el7 epel
mono-devel.x86_64 6.8.0-1.el7 epel
mono-extras.x86_64 6.8.0-1.el7 epel
mono-mvc.x86_64 6.8.0-1.el7 epel
mono-wcf.x86_64 6.8.0-1.el7 epel
mono-web.x86_64 6.8.0-1.el7 epel
mono-winforms.x86_64 6.8.0-1.el7 epel
If I start the upgrade
--> Processing Dependency: /usr/bin/python3 for package: mono-core-6.8.0-1.el7.x86_64
---> Package monodoc.x86_64 0:6.8.0-1.el7 will be installed
Error: Package: mono-winfxcore-5.18.1.0-0.xamarin.1.epel7.x86_64 (@download.mono-project.com_repo_centos7_)
Requires: mono-core = 5.18.1.0
Removing: mono-core-5.18.1.0-0.xamarin.1.epel7.x86_64 (@download.mono-project.com_repo_centos7_)
mono-core = 5.18.1.0-0.xamarin.1.epel7
Updated By: mono-core-6.8.0-1.el7.x86_64 (epel)
mono-core = 6.8.0-1.el7
Error: Package: mono-core-6.8.0-1.el7.x86_64 (epel)
Requires: /usr/bin/python3
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
I have python 3.6 installed
[root@nethserver1 ~]# ls -lai /usr/bin/python
123 lrwxrwxrwx 1 root root 7 Sep 11 2019 /usr/bin/python -> python2
[root@nethserver1 ~]# ls -lai /usr/bin/python3
669030 lrwxrwxrwx 1 root root 40 Oct 15 08:37 /usr/bin/python3 -> /opt/rh/rh-python36/root/usr/bin/python3
