WINBIND / SAMBA 4 & Radius [DC / SSSD and RADIUS]
Hello!
I do not dare to ask for yet another feature request :innocent:
Is there a planning that the account controllers are supplemented with the RADIUS?
In the spring of 2016, this was already discussed in the forum, and abes gave no concrete result.
So I would be happy!
Many greetings
It was already on the ShortTime agenda.
But unfortunately there was no reaction!
Is there anything else in the planning, or is there a new fact?
Nothing planned by now AFAIK. We could ask @alefattorini or @jobezic: RADIUS could be required by the captive-portal module (NS-enterprise).
BTW, RADIUS support in SSSD seems still under development!
https://fedorahosted.org/sssd/ticket/1162
It could be available an Active Directory integration, though.
@gerald_FS: why do you need it? What is your goal? Could you share your requirements?
@davidep
Currently I try to centralize WLAN with Ubiquiti, to complete coverage, I have distributed four access point in the house.
A central identification with RADIUS would put the whole project on a new level.
Some time ago I have with Ubuntu and Radius (2) and the WPA2 somewhat expiermenitert and it worked wonderfully.
This is my HowTo: http://wiki.pratznschutz.com/index.php/RADIUS_with_Samba4_AD_und_MSCHAPv2
It is not an economic constraint behind it!
Whether the identification is done with SSSD or in AD, I believe has little impact.
In addition, I am working in an aid organization and there are always problems with the central WLAN password.
If it works with me at home with 12 users I want this system to roll out there.
Greetings from the snow!
Gerald
Hello,
I am playing from a setup of a RADIUS server to the WLAN login.
ALs basis I use the following HowTo , however, I have already problems with the examination if I via Winbind my users can identify.
[Root @ openzwo samba] # ntlm_auth --username = test.mueller --domain = nandlnet.lan
Password:
Could not obtain winbind separator!
Reading winbind reply failed! (0x01)
: (0x0)
Does someone know any advice?
Greetings!
Currently, it’s not in the cards but looks very cool maybe @acsel10 made it work
