hi,
I want to ask can NethServer act as WiFI controller or WiFi manager?
Thank you
hi,
Thank you
We do not have any interface for that, but if you find a good guide for CentOS, you can try it and let us know!
This could work using Radius? Then some rules can be set on requests coming from wireless AP’s when authenticating to the LAN.
AFAIK the enterprise version has a cloud hotspot solution but not WiFi manager or controller.
What is your aim? Do you like to install something like the Unifi Controller?
I don’t know if @Simonvetterli or @jim can help you on this.
Or perhaps it’s a captive portal which is requested…
