Hello:
I need more alias interface. Can make more manual create ifcfg-ethX:X in /etc/sysconfig/network-scripts but i think that can create in the web interface will be a good idea. Is in “progress” for a new version?
Thanks¡
Hello:
Thanks¡
From the network menu I can create as many alias I want.
Now I have 3 working.
What problem did you encounter?
Ok¡¡¡¡ When i try to create another, edit the only one i have… i don’t know what happend this morning
Thanks¡¡¡¡¡¡
