Thanks to my friend @Tbaile I’d like to explain why NethServer help sysadmins administer, deploy and scale applications.
Managing containers, even just the execution of the container itself or backups, can be an immense pain. Take the example of backing up a container—everyone does it differently, every backup application has its methods, and if you change the way you use it, there’s a chance it’ll provide additional backup options. In short, it’s a disaster.
Here, we offer a unique solution that I haven’t seen elsewhere. Even the simple ability to move a container from one node to another without manual intervention is something that doesn’t exist outside (unless you’re dealing with massive setups like Kubernetes, but even then, you have to configure it manually—good luck).
