Whitelist and blacklist not effective with POP3 connector
:thinking: now that we have a reasonable fix for the discared mails we can look at this one too… /cc @stephdl
Probably the whitelist/blacklist cannot work with getmail because they are evaluated only with a SMTP envelope… Let’s try to reproduce it.
I am quite confident that getMail is whitelist aware, I can find it in side the maillog that @wbilger gave us
I would be so happy if you are right!
:smiling_imp: not-a-bug is far better than wont-fix
<6467506.1580747919703.JavaMail.wwwrun@localmail.loss.com>: set pre-result to 'no action' (no score): 'Matched map: FROM_SUBDOMAINS_WHITELIST' from multimap(1)
Feb  3 11:40:19 lrtserv-data rspamd[26933]: <8d008f>; csession; rspamd_task_write_log: id: <6467506.1580747919703.JavaMail.wwwrun@localmail.londonroos.com>, ip: 127.0.0.1, from: <tonia@londos.com>, (default: F (no action): [0.00/15.00] [FROM_SUBDOMAINS_WHITELIST(0.00){domain.com;}]), len: 1404, time: 3.217ms, dns req: 0, digest: <8e42e44498f4cc7e80faed013c49ded4>, mime_rcpts: <sam@domain.com>, file: stdin, forced: no action "Matched map: FROM_SUBDOMAINS_WHITELIST"; score=nan (set by multimap)
I think so, this was when first trying to find the soft reject issue, but I corrected after that a re bulk-import of whitelist settings overwrote what I had in there. So I think this was a mistake on my part.
but @davidep when you reject the email and you delete it with getmail from the remote server …what it happen ?
 Feb  7 17:49:14 prometheus rspamd[31990]: <1b5e12>; csession; rspamd_add_passthrough_result: <37B8F13771AD4CBEA4F52A0D3AF2B154@EMEA.FS.UTC.com>: set pre-result to 'reject' (no score): 'Sender email address rejected' from force_actions(1)
Feb  7 17:49:29 prometheus rspamd[31990]: <1b5e12>; lua; clamav.lua:119: clamav: failed to scan, maximum retransmits exceed
Feb  7 17:49:29 prometheus rspamd[31990]: <1b5e12>; lua; common.lua:107: clamav: result - FAILED with error: "failed to scan and retransmits exceed - score: 0"
Feb  7 17:49:29 prometheus rspamd[31990]: <1b5e12>; csession; rspamd_task_write_log: id: <37B8F13771AD4CBEA4F52A0D3AF2B154@EMEA.FS.UTC.com>, ip: 127.0.0.1, from: <devoir.de.conseil@chubb.fr>, (default: T (reject): [-0.10/19.90] [MIME_GOOD(-0.10){multipart/mixed;text/plain;},CLAM_VIRUS_FAIL(0.00){failed to scan and retransmits exceed;},FORCE_ACTION_REJECT_FROM_BLACKLIST(0.00){reject;},FROM_BLACKLIST(0.00){devoir.de.conseil@chubb.fr;},FROM_EQ_ENVFROM(0.00){},FROM_NO_DN(0.00){},HAS_REPLYTO(0.00){devoir.de.conseil@chubb.fr;},MIME_TRACE(0.00){0:+;1:+;2:~;},REPLYTO_EQ_FROM(0.00){}]), len: 357882, time: 15006.329ms, dns req: 0, digest: <7b97fe11554dad5fc5d7ff49a96d5aab>, mime_rcpts: <luc.fabre@chubb.fr,maisonderetraite.sauveterre@wanadoo.fr,stephane@de-labrusse.fr...>, file: stdin, forced: reject "Sender email address rejected"; score=nan (set by force_actions)
Feb  7 17:49:29 prometheus rspamd[31990]: <1b5e12>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 184 regexps total, 0 regexps cached, 0B scanned using pcre, 0B scanned total
Feb  7 17:49:30 prometheus dovecot: lda(toto@de-labrusse.fr): sieve: msgid=<37B8F13771AD4CBEA4F52A0D3AF2B154@EMEA.FS.UTC.com>: marked message to be discarded if not explicitly delivered (discard action)
Feb  7 17:49:30 prometheus getmail: msg  4/31 (362433 bytes) msgid 597083610/36139 from <devoir.de.conseil@chubb.fr> delivered to MDA_external command dovecot-lda (), deleted
By your log, if a message hits a blacklist:
  • it is delivered and discarded by sieve
  • it is expunged from the remote server
It is destroyed, as expected. Good news so.
The blacklist works. What about the whitelist?
I have mydomain.com in my whitelist.
I just sent a test message to one of my users with a spam signature in the content of the message, and the message was rejected (message was retrieved by getmail). Is the whitelist supposed to completely bypass spam filtering?
Yes, as ever we need log lines, what is the spam signature
I have this in the body of the message;
XJS*C4JDBQADN1.NSBN3*2IDNEN*GTUBE-STANDARD-ANTI-UBE-TEST-EMAIL*C.34X
mydomain.com is in Allow From whitelist
Here’s the log;
Feb 8 09:40:03 lrtserv-data rspamd[2939]: ; csession; rspamd_controller_check_password: allow unauthorized connection from a trusted IP 127.0.0.1
Feb 8 09:40:03 lrtserv-data rspamd[2939]: ; csession; rspamd_message_parse: loaded message; id: 7e7a9f7842a1f264ff5467a814cd3c56@mydomain.com; queue-id: ; size: 1085; checksum:
Feb 8 09:40:03 lrtserv-data rspamd[2939]: ; csession; rspamd_check_gtube: gtube reject pattern has been found in part of length 69
Feb 8 09:40:03 lrtserv-data rspamd[2939]: ; csession; rspamd_add_passthrough_result: 7e7a9f7842a1f264ff5467a814cd3c56@mydomain.com: set pre-result to ‘reject’ (15.00): ‘Gtube pattern’ from GTUBE(3)
Feb 8 09:40:03 lrtserv-data rspamd[2939]: ; csession; rspamd_task_write_log: id: 7e7a9f7842a1f264ff5467a814cd3c56@mydomain.com, ip: 127.0.0.1, from: test@mydomain.com, (default: S (reject): [15.00/15.00] [GTUBE(0.00){}]), len: 1085, time: 0.966ms, dns req: 0, digest: , mime_rcpts: wayne@mydomain.com, file: stdin, forced: reject “Gtube pattern”; score=15.00 (set by GTUBE)
Feb 8 09:40:03 lrtserv-data rspamd[2939]: ; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 184 regexps total, 0 regexps cached, 0B scanned using pcre, 0B scanned total
Feb 8 09:40:03 lrtserv-data dovecot: lda(wayne@mydomain.com): sieve: msgid=7e7a9f7842a1f264ff5467a814cd3c56@mydomain.com: marked message to be discarded if not explicitly delivered (discard action)
Feb 8 09:40:03 lrtserv-data getmail: msg 103/103 (1113 bytes) msgid 1580749373/126 from test@mydomain.com delivered to MDA_external command dovecot-lda ()
Feb 8 09:40:17 lrtserv-data rspamd[2939]: ; lua; bayes_expiry.lua:437: finished expiry step 674: 1001 items checked, 121 significant (4 made persistent), 0 insignificant (0 ttls set), 1 common (0 discriminated), 879 infrequent (33 ttls set), 7 mean, 43 std
Feb 8 09:40:21 lrtserv-data clamd[3050]: SelfCheck: Database status OK.
Feb 8 09:40:34 lrtserv-data rspamd[2939]: <3e3c2f>; csession; rspamd_controller_check_password: allow unauthorized connection from a trusted IP 127.0.0.1
Feb 8 09:40:34 lrtserv-data rspamd[2939]: <04707d>; csession; rspamd_controller_check_password: allow unauthorized connection from a trusted IP 127.0.0.1
Feb 8 09:41:51 lrtserv-data rspamd[2939]: ; lua; bayes_expiry.lua:437: finished expiry step 675: 999 items checked, 135 significant (13 made persistent), 1 insignificant (0 ttls set), 0 common (0 discriminated), 863 infrequent (9 ttls set), 5 mean, 19 std
It is normal, the spam signature is a test and it is checked before all filters
This spam signature is a test for rspamd and a mandatory to check before all others map/modules
So nothing to declare, to do , to check
However we have talked about getMail with @davidep this friday, we think to display a banner, be aware you can loose an email if you delete the emails from the remote server and the fetched emails has been rejected by ourself.
