I updated all my packages and logged into cockpit and it was still work
Then i was working in the “Terminal” part of cockpit and then somehow it stopped suddenly.
After a restart i can login to cockpit but all i get is a white page
Refreshing the page gets me back to the login screen
The old manager works just fine.
I looked at the /var/log/messages and i see some sessions getting created then i see session timed out.
Could it be that somehow the “Terminal” session got stuck somewhere and the issue is somewhere there ?
How could i debug this and how could i fix this ?
The old server manager works fine but i think there are options that are only available on the new server manager / Cockpit interface.
If anyone could help me out with this i would greatly appreciate it.
I removed the new manager and now re-added it via the old manager interface
The old manager when going to the software packages said i need to press the clean yum button, so i did.
After that i added back the new server manager.
And now it works
I still going to paste the /var/log/messages here when logging in. There seems to be 30 root sessions ? Why ? I didnt even login. There are also some other interresting messages there.
Blockquote
Sep 30 11:14:01 stshaintmail systemd: Started Session 30 of user root.
Sep 30 11:34:58 stshaintmail systemd: Removed slice User Slice of root.
Sep 30 12:01:01 stshaintmail systemd: Created slice User Slice of root.
Sep 30 12:01:01 stshaintmail systemd: Started Session 31 of user root.
Sep 30 12:01:01 stshaintmail systemd: Removed slice User Slice of root.
Sep 30 12:06:56 stshaintmail sshd[6981]: Accepted keyboard-interactive/pam for root from 192.168.0.100 port 46016 ssh2
Sep 30 12:06:56 stshaintmail systemd: Created slice User Slice of root.
Sep 30 12:06:56 stshaintmail systemd: Started Session 32 of user root.
Sep 30 12:06:56 stshaintmail systemd-logind: New session 32 of user root.
Sep 30 12:07:46 stshaintmail systemd: Starting Cockpit Web Service…
Sep 30 12:07:46 stshaintmail systemd: Started Cockpit Web Service.
Sep 30 12:07:46 stshaintmail cockpit-ws: Using certificate: /etc/cockpit/ws-certs.d/99-nethserver.cert
Sep 30 12:07:47 stshaintmail cockpit-ws: couldn’t read from connection: Peer sent fatal TLS alert: Unknown certificate
Sep 30 12:07:50 stshaintmail cockpit-ws: couldn’t read from connection: Peer sent fatal TLS alert: Unknown certificate
Sep 30 12:07:52 stshaintmail cockpit-ws: couldn’t read from connection: Peer sent fatal TLS alert: Unknown certificate
Sep 30 12:08:38 stshaintmail cockpit-ws: couldn’t read from connection: Peer sent fatal TLS alert: Unknown certificate
Sep 30 12:08:39 stshaintmail cockpit-session: pam_ssh_add: Failed adding some keys
Sep 30 12:08:39 stshaintmail systemd-logind: New session 33 of user root.
Sep 30 12:08:39 stshaintmail systemd: Started Session 33 of user root.
Sep 30 12:08:39 stshaintmail cockpit-ws: logged in user session
Sep 30 12:08:42 stshaintmail cockpit-ws: couldn’t read from connection: Peer sent fatal TLS alert: Unknown certificate
Sep 30 12:08:43 stshaintmail cockpit-ws: couldn’t read from connection: Peer sent fatal TLS alert: Unknown certificate
Sep 30 12:08:44 stshaintmail cockpit-ws: couldn’t read from connection: Peer sent fatal TLS alert: Unknown certificate
Sep 30 12:08:45 stshaintmail cockpit-ws: couldn’t read from connection: Peer sent fatal TLS alert: Unknown certificate
Sep 30 12:08:45 stshaintmail cockpit-ws: New connection to session from 192.168.0.8
Sep 30 12:08:46 stshaintmail dbus[587]: [system] Activating via systemd: service name=‘org.freedesktop.timedate1’ unit=‘dbus-org.freedesktop.timedate1.service’
Sep 30 12:08:46 stshaintmail systemd: Starting Time & Date Service…
Sep 30 12:08:46 stshaintmail dbus[587]: [system] Successfully activated service ‘org.freedesktop.timedate1’
Sep 30 12:08:46 stshaintmail systemd: Started Time & Date Service.
Sep 30 12:08:46 stshaintmail dbus[587]: [system] Activating via systemd: service name=‘org.freedesktop.hostname1’ unit=‘dbus-org.freedesktop.hostname1.service’
Sep 30 12:08:46 stshaintmail dbus[587]: [system] Activating via systemd: service name=‘org.freedesktop.realmd’ unit=‘realmd.service’
Sep 30 12:08:46 stshaintmail systemd: Starting Hostname Service…
Sep 30 12:08:46 stshaintmail dbus[587]: [system] Successfully activated service ‘org.freedesktop.hostname1’
Sep 30 12:08:46 stshaintmail systemd: Started Hostname Service.
Sep 30 12:08:46 stshaintmail systemd: Starting Realm and Domain Configuration…
Sep 30 12:08:46 stshaintmail dbus[587]: [system] Successfully activated service ‘org.freedesktop.realmd’
Sep 30 12:08:46 stshaintmail systemd: Started Realm and Domain Configuration.
Sep 30 12:08:47 stshaintmail cockpit-ws: couldn’t read from connection: Peer sent fatal TLS alert: Unknown certificate
Sep 30 12:08:49 stshaintmail cockpit-bridge: No entry for terminal type “unknown”;
Sep 30 12:08:49 stshaintmail cockpit-bridge: using dumb terminal settings.
