I uploaded a website via ftp, but I cannot find it on the command line in terminal.
I presume somewhere in /var/www but if you are looking for something, you should try either
locate <FileOrFolderName'>
(do before ‘yum install mlocate -y ; updatedb’)
or
find / -iname 'FileOrFolderName'
Shared folder are saved inside the /var/lib/nethserver/ibay/<sitename>.
Ehi man, take a look at this discussion I’m sure that you’re interested in
