Hello, What problem is this, why I can get conection
10.0.40.30 TAG_NONE/503 0 CONNECT mail.senagua.gob.ec:443 - HIER_NONE/- -
The site has an untrusted certificate but it just works with my NethServer proxy:
[root@server ~]# cat /var/log/squid/access.log | grep mail.senagua.gob.ec 1514912443.240 435 x.x.x.x TCP_TUNNEL/200 995 CONNECT mail.senagua.gob.ec:443 - ORIGINAL_DST/x.x.x.x -
Did you customize your proxy? You may try to whitelist (sites without proxy) this site in your proxy settingsā¦
I put the domain en white list⦠but the problem is the same; I read of squid have a problem and said to put in squid.conf these line dns_v4_first on ; what of true is.?
Here is a explanation how to do it with a custom template:
I put that line and what happens⦠mkdir -p /etc/e-smith/templates-custom/etc/squid
echo ādns_v4_first onā >/etc/e-smith/templates-custom/etc/squid/91ipv4dns
signal-event nethserver-squid-save
It“s create a new archive⦠or what.?
No, it applies the ādns_v4_first onā setting to NethServer. NethServer uses a template system to write config files. You just created a custom template to change squid config and fired an event nethserver-squid-save to apply it.
