What does Nethsever while installation with the second HDD?
after a new Installation of Nethserver, my second HDD ist out of Order!
There is no FS to read from the disk :frowning:
how can I retrieve the data?
Disk /dev/sdb: 2000.4 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0x0008504a
   Device Boot      Start         End      Blocks   Id  System
Disk /dev/sda: 160.0 GB, 160041885696 bytes
255 heads, 63 sectors/track, 19457 cylinders
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x2daf2daf
/dev/sda1   *           1          66      524288   83  Linux
Partition 1 does not end on cylinder boundary.
/dev/sda2              66       19458   155764736   8e  Linux LVM
Disk /dev/mapper/VolGroup-lv_swap: 4127 MB, 4127195136 bytes
255 heads, 63 sectors/track, 501 cylinders
Disk identifier: 0x00000000
Nicky
Could you please past the output of following commands?
  • pvs
  • cat /proc/mdstat
[root@home /]# pvs
  PV         VG       Fmt  Attr PSize   PFree
  /dev/sda2  VolGroup lvm2 a--  148.53g    0
[root@home /]# cat /proc/mdstat
Personalities :
unused devices: < none >
Nicky
All Data are back :grin:
Command was e2fsck
Nicky
Write some notes of what you did…we could start to undestand what it occured
@supernicky please give us a complete solution so we can mark this thread as solved
