I would like to know, in brief, what are fragments, how NethServer uses them and a couple of examples if possible.
Fragments are portions of templates: http://docs.nethserver.org/projects/nethserver-devel/en/latest/templates.html
in brief
fragments are part of code, stored into /etc/e-smith/templates tree (and in templates-custom tree)
they can be plain text files or (often) perl scripts that read values from db and use them to create a part (or whole) conf file…
and example…
let’s say we have a service myservice that needs its conf file in /etc/myservice/ dir, named myservice.conf
first of all I create the right path:
mkdir -p /etc/e-smith/templates/etc/myservice/myservice.conf
then I move into the new dir and create my template fragments; the naming convention is XYfragmentname, where XY are numbers and fragmentname is something that helps to identify the role/content
this is valid for NEW services
N.B. acting this way is the RIGHT way… be aware that all the /templates/ tree is NOT backuped
usually, users must not edit fragments into the /template/ tree…
if I need to add or override some default part in the conf file, I must:
create the corrisponding path into the /templates-custom/ tree
following the above example
mkdir -p /etc/e-smith/templates-custom/etc/myservice/myservice.conf
then:
if you want to add a value, just create in that dir a file YZmyfragment with the needed code/content
since fragments are evaluated in numeric order, choose YX accordingly to your need
for exampke, creating a 15myfragment, its content will be between content of 10fragment and 20fragment in the resulting file -
if you need to override something, just copy the involved fragment from /templates/ tree into this directory and edit it accordingly to your need; it’s content will override the content of the “original” fragment
fragments are evaluated and expanded into their final conf files with the
expand-template templatename
command
if/when you don’t need anymore your customization, removing the relevant fragment and re expanding the template will undo everything
uysually you don’t need to use the expand-template command, but you use the rigth event to exmpand it and restart involved services
as I said above, the content of /templates-custom/ tree is always included into backups (as db files)
it contains alla the customization you have done to your setup and it is needed to restore the server features.
be aware that sometimes, usually after a data restore on a new hardware (and maybe a new O.S. release), you should always check your custom fragments to avoid problems
