Hi all.
I have problem with autentication of user in webtop5 on NS machine binded via ldap to NS AD Server.
Probably the problem is born for different kernel and sssd version running on this 2 NS server ( many package as changed in the last year ).
i have try to unbind and rebind LDAP with automatic check configuration, and all check is ok.
i have try to reinstall webtop5 and nethserver-webtop5, this is the messages output
2018-03-09 12:13:51 [INFO ] c.sonicle.webtop.core.app.WebTopApp - webtop.extJsDebug = false
2018-03-09 12:13:51 [INFO ] c.sonicle.webtop.core.app.WebTopApp - webtop.soExtDevMode = false
2018-03-09 12:13:51 [INFO ] c.sonicle.webtop.core.app.WebTopApp - webtop.devMode = true
2018-03-09 12:13:51 [INFO ] c.sonicle.webtop.core.app.WebTopApp - webtop.debugMode = false
2018-03-09 12:13:51 [INFO ] c.sonicle.webtop.core.app.WebTopApp - webtop.schedulerSisabled = false
2018-03-09 12:13:51 [INFO ] c.sonicle.webtop.core.app.WebTopApp - webtop.webappsConfigPath = null
2018-03-09 12:13:53 [INFO ] c.sonicle.webtop.core.app.WebTopApp - WTA initialization started [webtop]
2018-03-09 12:13:53 [INFO ] c.s.w.core.app.ConnectionManager - Initialized
2018-03-09 12:13:53 [INFO ] c.s.webtop.core.app.SettingsManager - Initialized
2018-03-09 12:13:53 [INFO ] c.s.webtop.core.app.SessionManager - Initialized
2018-03-09 12:13:53 [INFO ] c.sonicle.webtop.core.app.WebTopApp - Checking home structure...
2018-03-09 12:13:54 [INFO ] c.s.webtop.core.app.I18nManager - Initialized
2018-03-09 12:13:54 [INFO ] c.sonicle.webtop.core.app.WebTopApp - Initializing template engine
2018-03-09 12:13:54 [INFO ] c.sonicle.webtop.core.app.LogManager - Initialized
2018-03-09 12:13:54 [INFO ] c.s.webtop.core.app.WebTopManager - Initialized
2018-03-09 12:13:54 [INFO ] c.sonicle.webtop.core.app.OTPManager - Initialized
2018-03-09 12:13:54 [INFO ] c.s.webtop.core.app.ReportManager - Initialized
2018-03-09 12:13:54 [INFO ] c.s.webtop.core.app.ServiceManager - Registering service [com.sonicle.webtop.core]
2018-03-09 12:13:54 [INFO ] c.s.webtop.core.app.ServiceManager - [private:true, public:true, job:true, userOptions:true]
2018-03-09 12:13:54 [INFO ] c.s.webtop.core.app.ServiceManager - Not upgraded! [5.1.5 = 5.1.5]
2018-03-09 12:13:54 [INFO ] c.s.webtop.core.app.ServiceManager - Database upgrades will be appended to 1520594034275
2018-03-09 12:13:54 [INFO ] c.s.webtop.core.app.ServiceManager - Registering service [com.sonicle.webtop.core.admin]
2018-03-09 12:13:54 [INFO ] c.s.webtop.core.app.ServiceManager - [private:true, public:false, job:false, userOptions:false]
2018-03-09 12:13:54 [WARN ] c.s.webtop.core.app.ServiceManager - Service descriptor for 'wtdrm' version @@webtop.service.version@@ skipped. Cause: Invalid value for property [version]
2018-03-09 12:13:54 [INFO ] c.s.webtop.core.app.ServiceManager - Registering service [com.sonicle.webtop.calendar]
2018-03-09 12:13:54 [INFO ] c.s.webtop.core.app.ServiceManager - [private:true, public:true, job:false, userOptions:true]
2018-03-09 12:13:54 [INFO ] c.s.webtop.core.app.ServiceManager - Not upgraded! [5.1.9 = 5.1.9]
2018-03-09 12:13:54 [INFO ] c.s.webtop.core.app.ServiceManager - Registering service [com.sonicle.webtop.contacts]
2018-03-09 12:13:54 [INFO ] c.s.webtop.core.app.ServiceManager - [private:true, public:false, job:false, userOptions:true]
2018-03-09 12:13:54 [INFO ] c.s.webtop.core.app.ServiceManager - Not upgraded! [5.1.7 = 5.1.7]
2018-03-09 12:13:54 [INFO ] c.s.webtop.core.app.ServiceManager - Registering service [com.sonicle.webtop.mail]
2018-03-09 12:13:54 [INFO ] c.s.webtop.core.app.ServiceManager - [private:true, public:false, job:true, userOptions:true]
2018-03-09 12:13:54 [INFO ] c.s.webtop.core.app.ServiceManager - Not upgraded! [5.1.4 = 5.1.4]
2018-03-09 12:13:54 [INFO ] c.s.webtop.core.app.ServiceManager - Registering service [com.sonicle.webtop.tasks]
2018-03-09 12:13:54 [INFO ] c.s.webtop.core.app.ServiceManager - Not upgraded! [5.1.3 = 5.1.3]
2018-03-09 12:13:54 [INFO ] c.s.webtop.core.app.ServiceManager - Registering service [com.sonicle.webtop.vfs]
2018-03-09 12:13:54 [INFO ] c.s.webtop.core.app.ServiceManager - Not upgraded! [5.0.12 = 5.0.12]
2018-03-09 12:13:54 [INFO ] c.s.webtop.core.app.ServiceManager - Maintenance mode: false
2018-03-09 12:13:54 [INFO ] c.s.webtop.core.app.ServiceManager - Initialized
2018-03-09 12:13:54 [INFO ] c.sonicle.webtop.core.app.WebTopApp - WTA initialization completed [webtop]
2018-03-09 12:13:59 [INFO ] c.sonicle.webtop.core.app.WebTopApp - Checking domains homes structure...
2018-03-09 12:13:59 [INFO ] c.sonicle.webtop.core.app.WebTopApp - Checking webapp version...
2018-03-09 12:13:59 [WARN ] c.sonicle.webtop.core.app.WebTopApp - No configuration found for TomcatManager [tomcat.manager.uri]
2018-03-09 12:13:59 [WARN ] c.sonicle.webtop.core.app.WebTopApp - Webapp version automatic check will NOT be performed!
2018-03-09 12:13:59 [INFO ] c.sonicle.webtop.core.app.WebTopApp - This webapp [webtop] is the latest
2018-03-09 12:14:59 [INFO ] c.sonicle.webtop.core.app.WebTopApp - Scheduling JobServices tasks...
2018-03-09 12:14:59 [INFO ] c.sonicle.webtop.core.app.WebTopApp - Created javax.mail.Session for localhost:587
now if try to login with user that never logged in webtop, in webtop.log
2018-03-09 13:10:15 [ERROR] com.sonicle.webtop.mail.Service - Error connecting to the mail server
javax.mail.AuthenticationFailedException: [UNAVAILABLE] Temporary authentication failure. [proxy:2018-03-09 12:10:15]
at com.sun.mail.imap.IMAPStore.protocolConnect(IMAPStore.java:723)
at javax.mail.Service.connect(Service.java:364)
at com.sonicle.webtop.mail.Service.connect(Service.java:525)
at com.sonicle.webtop.mail.Service.validateUser(Service.java:576)
at com.sonicle.webtop.mail.Service.checkStoreConnected(Service.java:479)
at com.sonicle.webtop.mail.Service.initialize(Service.java:393)
at com.sonicle.webtop.core.app.ServiceManager.instantiatePrivateService(ServiceManager.java:815)
at com.sonicle.webtop.core.app.WebTopSession.internalInitPrivateEnvironment(WebTopSession.java:479)
at com.sonicle.webtop.core.app.WebTopSession.initPrivateEnvironment(WebTopSession.java:398)
at com.sonicle.webtop.core.servlet.Start.processRequest(Start.java:91)
at com.sonicle.webtop.core.app.AbstractServlet.doGet(AbstractServlet.java:73)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.apache.shiro.web.servlet.ProxiedFilterChain.doFilter(ProxiedFilterChain.java:61)
at org.apache.shiro.web.servlet.AdviceFilter.executeChain(AdviceFilter.java:108)
at org.apache.shiro.web.servlet.AdviceFilter.doFilterInternal(AdviceFilter.java:137)
at org.apache.shiro.web.servlet.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:125)
at org.apache.shiro.web.servlet.ProxiedFilterChain.doFilter(ProxiedFilterChain.java:66)
at com.sonicle.webtop.core.shiro.filter.GZip.doFilterInternal(GZip.java:60)
at org.apache.shiro.web.servlet.AbstractShiroFilter.executeChain(AbstractShiroFilter.java:449)
at org.apache.shiro.web.servlet.AbstractShiroFilter$1.call(AbstractShiroFilter.java:365)
at org.apache.shiro.subject.support.SubjectCallable.doCall(SubjectCallable.java:90)
at org.apache.shiro.subject.support.SubjectCallable.call(SubjectCallable.java:83)
at org.apache.shiro.subject.support.DelegatingSubject.execute(DelegatingSubject.java:383)
at org.apache.shiro.web.servlet.AbstractShiroFilter.doFilterInternal(AbstractShiroFilter.java:362)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:218)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:110)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:506)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:169)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:962)
at org.apache.catalina.valves.RemoteIpValve.invoke(RemoteIpValve.java:683)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:445)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1087)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:637)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:318)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1152)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:622)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748)
2018-03-09 13:10:15 [ERROR] com.sonicle.webtop.mail.Service - Exception
javax.mail.MessagingException: failed to create new store connection
at com.sun.mail.imap.IMAPStore.hasCapability(IMAPStore.java:1460)
at com.sonicle.webtop.mail.Service.initialize(Service.java:395)
Caused by: com.sun.mail.iap.ConnectionException: failed to create new store connection
at com.sun.mail.imap.IMAPStore.getStoreProtocol(IMAPStore.java:1084)
at com.sun.mail.imap.IMAPStore.hasCapability(IMAPStore.java:1457)
... 52 common frames omitted
2018-03-09 13:10:17 [ERROR] com.sonicle.webtop.mail.Service - Error in PortletMail
java.lang.NullPointerException: null
at com.sonicle.webtop.mail.Service.processPortletMail(Service.java:5198)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at com.sonicle.webtop.core.servlet.BaseRequest.invokeMethod(BaseRequest.java:109)
at com.sonicle.webtop.core.servlet.PrivateRequest.processRequest(PrivateRequest.java:83)
at com.sonicle.webtop.core.servlet.PrivateRequest.doGet(PrivateRequest.java:119)
2018-03-09 13:10:22 [ERROR] c.s.webtop.core.xmpp.XMPPClient - Unable to login
org.jivesoftware.smack.SmackException$NoResponseException: No response received within reply timeout. Timeout was 5000ms (~5s). While waiting for successful SASL authentication
at org.jivesoftware.smack.SmackException$NoResponseException.newWith(SmackException.java:92)
at org.jivesoftware.smack.SASLAuthentication.authenticate(SASLAuthentication.java:223)
at org.jivesoftware.smack.tcp.XMPPTCPConnection.loginInternal(XMPPTCPConnection.java:385)
at org.jivesoftware.smack.AbstractXMPPConnection.login(AbstractXMPPConnection.java:491)
at org.jivesoftware.smack.AbstractXMPPConnection.login(AbstractXMPPConnection.java:448)
at com.sonicle.webtop.core.xmpp.XMPPClient.internalLogin(XMPPClient.java:918)
at com.sonicle.webtop.core.xmpp.XMPPClient.checkAuthentication(XMPPClient.java:1000)
at com.sonicle.webtop.core.xmpp.XMPPClient.updatePresence(XMPPClient.java:204)
at com.sonicle.webtop.core.Service.processManageIM(Service.java:1321)
at com.sonicle.webtop.core.servlet.PrivateRequest.doPost(PrivateRequest.java:114)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:650)
Caused by: com.sonicle.webtop.core.xmpp.XMPPClientException: org.jivesoftware.smack.SmackException$NoResponseException: No response received within reply timeout. Timeout was 5000ms (~5s). While waiting for successful SASL authentication
at com.sonicle.webtop.core.xmpp.XMPPClient.checkAuthentication(XMPPClient.java:1003)
... 57 common frames omitted
Caused by: org.jivesoftware.smack.SmackException$NoResponseException: No response received within reply timeout. Timeout was 5000ms (~5s). While waiting for successful SASL authentication
... 59 common frames omitted
another error is this
[root@proxy ~]# yum update postgresql
* base: it.centos.contactlab.it
* epel: pkg.adfinis-sygroup.ch
* extras: it.centos.contactlab.it
* nethforge: mirror2.nethserver.org
* nethserver-base: mirror2.nethserver.org
* nethserver-updates: mirror2.nethserver.org
* rpmfusion-free-updates: fr2.rpmfind.net
* updates: it.centos.contactlab.it
Resolving Dependencies
--> Running transaction check
---> Package postgresql.x86_64 0:9.2.23-1.el7_4 will be updated
--> Processing Dependency: postgresql(x86-64) = 9.2.23-1.el7_4 for package: postgresql-server-9.2.23-1.el7_4.x86_64
---> Package postgresql.x86_64 0:9.2.23-3.el7_4 will be an update
Error: Package: postgresql-server-9.2.23-1.el7_4.x86_64 (@updates)
Requires: postgresql(x86-64) = 9.2.23-1.el7_4
Removing: postgresql-9.2.23-1.el7_4.x86_64 (@updates)
Updated By: postgresql-9.2.23-3.el7_4.x86_64 (updates)
postgresql(x86-64) = 9.2.23-3.el7_4
Available: postgresql-9.2.21-1.el7.x86_64 (base)
postgresql(x86-64) = 9.2.21-1.el7
You could try using --skip-broken to work around the problem
** Found 5 pre-existing rpmdb problem(s), 'yum check' output follows:
dracut-033-502.el7_4.1.x86_64 is a duplicate with dracut-033-502.el7.x86_64
php-pear-Mail-Mime-1.10.2-1.el7.noarch is a duplicate with php-pear-Mail-Mime-1.10.1-1.el7.noarch
postgresql-9.2.23-3.el7_4.x86_64 is a duplicate with postgresql-9.2.23-1.el7_4.x86_64
postgresql-libs-9.2.23-3.el7_4.x86_64 is a duplicate with postgresql-libs-9.2.23-1.el7_4.x86_64
postgresql-server-9.2.23-3.el7_4.x86_64 is a duplicate with postgresql-server-9.2.23-1.el7_4.x86_64
Are these errors connected?
