After doing an import using pst2webtop.sh I wanted to reorganize the imported folders. The import itself worked fine and I could see the folders with the correct characters but when I try to drag and drop the folder nothing happens while it works fine for folders with standard ASCII characters. I then tried to rename the folder it said rename failed even if it looked correct in the UI until I choose to do a reload tree when it will show the original name again.
When moving a folder structure where one sub folder has a national character it works until it hits the folder with the national character and then it stops without moving any sub folders following that one. The characters that I experience problems with are åäöÅÄÖ.
