I try to demo webtop4, it is very good .However, how to get contact users and alias from LDAP Nethserver? I mean, autocomplete to, cc, bcc from LDAP Nethserver.
Thank you
Thank you
Hi, yes I believe there is a way to do it, let me think about it and will get back here.
Gabriele
Ok, it’s an old code to integrate public ldap directories, and it works only if the ldap server has public search access with no password.
@davidep : do you know of any “ldapsearch …” that can be done against nethserver ldap directory without authentication? Actually, if I remember well, we even had to implement a specific “admin” access to lookup the ldap description of a user, that was not available to a regular authenticated user.
On ns6 authenticated bind is always required (user’s credentials are good).
On ns7:
