RoccoB
(Rocco Brand)
1
NethServer Version: your_version
Module: your_module
Hi All,
I am experiencing the following SSL error when trying to access Webtop:
I have allowed https 443 and also changed the SSL cert files from .crt to .pem as per topics in the Nethserver community.
Please advise a solution or way to troubleshoot this further?
Thanking you in advance
Rocco Brand
mrmarkuz
(Markus Neuberger)
2
Hi @RoccoB,
Does the error only occur in webtop? It seems you have a bad certificate so I am afraid the whole webserver is affected.
Did you upload a certificate?
Please post the output of the following command to check the actual config:
config show pki
Did you change /etc/httpd/conf.d/ssl.conf
, if yes please post the output of:
grep SSLCert /etc/httpd/conf.d/ssl.conf
I also get this error when I try to open an http page with https. Do you do some port forwarding or reverse proxying?
RoccoB
(Rocco Brand)
3
Hi Markus
Thank you for your swift reply, I will get back to you on your queries ![:slight_smile: :slight_smile:](//community.nethserver.org/images/emoji/twitter/slight_smile.png?v=5)
