Hi, I have a fresh installation (for testing) of Nethserver. I installed all updates, Instant messaging, NextCloud and Webtop modules.
I configured Webtop for Instant messaging, NextCloud and set default user settings for German environment. I created two test users and logged in as both users in different browsers (Edge and Chrome).
When I create a schedule and add additional users (here: the second testuser), the other user don’t get an invitation. Is this a bug or is this how it should work?
See the attached screenshot how I added invited the second user.
To change massively on db this value (from false to true) for all the calendars currently present:
su - postgres -c "psql webtop5"
webtop5=# update calendar.calendars set invitation='t';
If you want to do it only for some calendar you can see the calendars on the db as follows:
webtop5=# select calendar_id,user_id,name,invitation from calendar.calendars;
then run the “update” query by selecting with “where” the calendar to be updated
Currently there is no global settings to modify the defualt of this setting, for this reason, every new calendar created will have again the invitation value set to ‘f’.
