NethServer Version: 7.9.2009
Module: WebTop
Hello, I am again evaluating Nethserver, this time behind a PfSense and HaProxy (single interface - lan). So far so good, there is just one thing with WebTop - the login page shows up as expected where I enter user and password, the page loads again and redirects to https://127.0.0.1/webtop/ cutting the connection. I hit the browser back button, do a refresh and I am in. What can I do to solve ths redrect issue?
Thanks, Peter
markareait
(Mark Albrecht)
December 26, 2023, 10:15am
2
I have the same issue after a restore. Did you find out a fix?
markareait
(Mark Albrecht)
December 26, 2023, 10:54pm
3
Still have not cleared.
Some notes -
Did another NethServer restore the same results. All other services working like coming / outgoing emails.
Affects all user accounts I have tested and affects login from other sites using other computers.
Webtop has no issues once I get in by hitting the browser back button, do a refresh to get in.
When I logout it redirects me to the same https://127.0.0.1/webtop/
Tried clearing Webtop cache
The public url is set correctly in Webtop.
Same proxy setup (Nginx Proxy Manager) as other sites and setting are the same.
Checked the webtop settings are the same as a working site.
Check if I could see errors in the Webtop DB, nothing found.
Webtop log shows nothing related to login time.
URL access only causes this issue. So, tf accessing Webtop from the server LAN IP address the issue is not present.
Has anyone got any other ideas?
markareait
(Mark Albrecht)
December 28, 2023, 3:40am
4
Gabriele Bulfon at Sonicle believes this issue is a NethServer issue -
https://sonicle.atlassian.net/browse/WT-1308
