/var/log/maillog
Feb 8 09:00:18 emails postfix/smtpd[31872]: connect from localhost[127.0.0.1]
Feb 8 09:00:18 emails rspamd[2035]: <8ee4cb>; proxy; proxy_accept_socket: accepted milter connection from /var/run/rspamd/worker-proxy port 0
Feb 8 09:00:18 emails postfix/smtpd[31872]: 611642257DE: client=localhost[127.0.0.1], sasl_method=LOGIN, sasl_username=mark@##removed##
Feb 8 09:00:18 emails rspamd[2035]: <8ee4cb>; milter; rspamd_milter_process_command: got connection from 127.0.0.1:59604
Feb 8 09:00:18 emails postfix/cleanup[31876]: 611642257DE: message-id=<265361742.63.1644271218285@emails.##removed##>
Feb 8 09:00:18 emails rspamd[2035]: <8ee4cb>; proxy; rspamd_message_parse: loaded message; id: <265361742.63.1644271218285@emails.##removed##>; queue-id: <611642257DE>; size: 7890; checksum:
Feb 8 09:00:18 emails rspamd[2035]: <8ee4cb>; proxy; html_url_is_phished: extract of url âmailto://list-3914@com.sonicle.webtop.contactsâ failed: TLD part is not detected; obfuscation detected: no
Feb 8 09:00:18 emails rspamd[2035]: <8ee4cb>; proxy; rspamd_mime_part_detect_language: detected part language: en
Feb 8 09:00:18 emails rspamd[2035]: <8ee4cb>; lua; settings.lua:366: <265361742.63.1644271218285@emails.##removed##> apply static settings authenticated (id = 1937017268); authenticated matched; priority high
Feb 8 09:00:18 emails rspamd[2035]: <8ee4cb>; proxy; rspamd_add_passthrough_result: <265361742.63.1644271218285@emails.##removed##>: set pre-result to âno actionâ (no score): âMatched map: IP_WHITELISTâ from multimap(1)
Feb 8 09:00:18 emails rspamd[2035]: <8ee4cb>; proxy; rspamd_task_write_log: id: <265361742.63.1644271218285@emails.##removed##>, qid: <611642257DE>, ip: 127.0.0.1, user: mark@##removed##, from: <mark@##removed##>, (default: F (no action): [0.00/20.00] [IP_WHITELIST(0.00){127.0.0.1;}]), len: 7890, time: 3.514ms, dns req: 0, digest: , rcpts: list-3914@com.sonicle.webtop.contacts, mime_rcpts: list-3914@com.sonicle.webtop.contacts, forced: no action âMatched map: IP_WHITELISTâ; score=nan (set by multimap), settings_id: authenticated
Feb 8 09:00:18 emails rspamd[2035]: <8ee4cb>; proxy; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 175 regexps total, 0 regexps cached, 0B scanned using pcre, 0B scanned total
Feb 8 09:00:18 emails opendkim[1208]: 611642257DE: DKIM-Signature field added (s=default, d=##removed##)
Feb 8 09:00:18 emails postfix/qmgr[1686]: 611642257DE: from=<mark@##removed##>, size=8188, nrcpt=1 (queue active)
Feb 8 09:00:18 emails postfix/smtpd[31872]: disconnect from localhost[127.0.0.1]
Feb 8 09:00:18 emails rspamd[2035]: ; proxy; proxy_milter_finish_handler: finished milter connection
Feb 8 09:00:18 emails postfix/smtp[31877]: 611642257DE: to=list-3914@com.sonicle.webtop.contacts, relay=none, delay=0.06, delays=0.03/0.01/0.02/0, dsn=5.4.4, status=bounced (Host or domain name not found. Name service error for name=com.sonicle.webtop.contacts type=AAAA: Host not found)
Feb 8 09:00:18 emails postfix/cleanup[31876]: 704A4261F1C: message-id=<20220207220018.704A4261F1C@emails.##removed##>
Feb 8 09:00:18 emails postfix/bounce[31878]: 611642257DE: sender non-delivery notification: 704A4261F1C
Feb 8 09:00:18 emails postfix/qmgr[1686]: 704A4261F1C: from=<>, size=11084, nrcpt=1 (queue active)
Feb 8 09:00:18 emails postfix/qmgr[1686]: 611642257DE: removed
Feb 8 09:00:18 emails dovecot: lmtp(31880): Connect from local
Feb 8 09:00:18 emails dovecot: lmtp(mark@##removed##): save: box=INBOX, uid=7994, msgid=<20220207220018.704A4261F1C@emails.##removed##>, from=MAILER-DAEMON@emails.##removed## (Mail Delivery System), subject=Undelivered Mail Returned to Sender, flags=()
Feb 8 09:00:18 emails dovecot: lmtp(mark@##removed##): eOG1HXKWAWKIfAAAEA1DJQ: sieve: msgid=<20220207220018.704A4261F1C@emails.##removed##>: stored mail into mailbox âINBOXâ
Feb 8 09:00:18 emails postfix/lmtp[31879]: 704A4261F1C: to=<mark@##removed##>, relay=emails.##removed##[/var/run/dovecot/lmtp], delay=0.07, delays=0.01/0.01/0.02/0.03, dsn=2.0.0, status=sent (250 2.0.0 <mark@##removed##> eOG1HXKWAWKIfAAAEA1DJQ Saved)
Feb 8 09:00:18 emails dovecot: lmtp(31880): Disconnect from local: Successful quit
Feb 8 09:00:18 emails postfix/qmgr[1686]: 704A4261F1C: removed
Feb 8 09:00:48 emails rspamd[2036]: <7oo5kb>; lua; bayes_expiry.lua:440: finished expiry step 35: 988 items checked, 171 significant (0 made persistent), 1 insignificant (0 ttls set), 0 common (0 discriminated), 816 infrequent (0 ttls set), 8 mean, 21 std
/var/log/messages
Feb 8 08:59:00 emails cockpit-bridge: No entry for terminal type âunknownâ;
Feb 8 08:59:00 emails cockpit-bridge: using dumb terminal settings.
Feb 8 08:59:01 emails cockpit-bridge: No entry for terminal type âunknownâ;
Feb 8 08:59:01 emails cockpit-bridge: using dumb terminal settings.
Feb 8 09:00:01 emails systemd: Started Session 449 of user root.
Feb 8 09:01:01 emails systemd: Started Session 450 of user root.
Feb 8 09:05:26 emails cockpit-ws: WebSocket from 192.168.0.209 for session closed
Feb 8 09:05:26 emails cockpit-ws: couldnât read from connection: Peer sent fatal TLS alert: Unknown certificate
Feb 8 09:05:27 emails dbus[745]: [system] Activating via systemd: service name=âorg.freedesktop.hostname1â unit=âdbus-org.freedesktop.hostname1.serviceâ
Feb 8 09:05:27 emails systemd: Starting Hostname ServiceâŚ
Feb 8 09:05:27 emails dbus[745]: [system] Successfully activated service âorg.freedesktop.hostname1â
Feb 8 09:05:27 emails systemd: Started Hostname Service.
Feb 8 09:05:28 emails cockpit-bridge: No entry for terminal type âunknownâ;
Feb 8 09:05:28 emails cockpit-bridge: using dumb terminal settings.
