I am not able to login to webtop or Roundcubemail…
I did a reboot but same problem… How can I start the services?
P.S. I use external LDAP
Webtop:
Enqueued anchor job 39 postgres.service/start.
Enqueued auxiliary job 54 z-push.service/start.
Enqueued auxiliary job 53 webtop.service/start.
Enqueued auxiliary job 55 webdav.service/start.
Enqueued auxiliary job 57 apache.service/start.
Enqueued auxiliary job 56 webapp.service/start.
DELETE 1
DELETE 1
INSERT 0 1
INSERT 0 1
DELETE 1
DELETE 1
INSERT 0 1
INSERT 0 1
DELETE 1
INSERT 0 1
bash: -c: line 1: unexpected EOF while looking for matching `"’
bash: -c: line 2: syntax error: unexpected end of file
File “/home/webtop1/.config/actions/configure-module/20config”, line 265, in
domain_setup(mail_domain, user_domain)
File “/home/webtop1/.config/actions/configure-module/20config”, line 19, in domain_setup
user_domain_password = subprocess.check_output([‘podman’, ‘run’, ‘–rm’, os.environ[“WEBTOP_WEBAPP_IMAGE”], ‘bash’, ‘-c’, “echo -n " + user_domain[“bind_password”] + " | java -classpath /usr/share/webtop/ WebtopPassEncode”], text=True).splitlines().pop()
File “/usr/lib/python3.11/subprocess.py”, line 466, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File “/usr/lib/python3.11/subprocess.py”, line 571, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command ‘[‘podman’, ‘run’, ‘–rm’, ‘Package webtop-webapp · GitHub’, ‘bash’, ‘-c’, ‘echo -n xxxxxxxxx | java -classpath /usr/share/webtop/ WebtopPassEncode’]’ returned non-zero exit status 2.
