schweidj
(Joachim Schweidler)
March 26, 2020, 8:22am
1
NethServer Version: 7.7.1908
Module: WebTop
I facing an issue where WebTop ActiveSync is not working correctly on an iPad with IPadOS 13.4 (also with 13.x). Nethserver is fully patched.
I set up the ActiveSync Account on the iPad. Everything get´s synced (calendar, contacts, Tasks) and mail.
But since then only mails are pushed correctly. Calendar events, tasks and contacts only get synced when I change something in the corresponding app on the iPad (e.g. deleting/changing or adding an event).
These are the webtop Settings:
webtop=configuration
ActiveSync=enabled
ActiveSyncLegacyIds=enabled
ActiveSyncLog=ERROR
DavServerLog=ERROR
DavServerUrl=
Debug=false
DefaultLocale=en_US
DefaultTimezone=Etc/UTC
DefaultToolbarIconsSize=medium
MaxMemory=1024
MinMemory=512
PbxProvider=
PbxProviderNethvoiceWebrestUrl=
PublicUrl=
RemoteCalendarAutosync=enabled
RemoteCalendarAutosyncOnlywhenonline=disabled
RemoteCategoryAutosync=enabled
RemoteCategoryAutosyncOnlywhenonline=disabled
Does anybody have a similar Problem?
pike
(Michael Kicks)
March 26, 2020, 8:29am
2
Does NethServer has a public FDQN?
Does NethServer issue a certificate for SSL connection?
Is UTC your actual timezone?
I would not suggest to use ActiveSync for mails, and use an imap client instead.
Try configure the AS account with only calendar and contacts active.
Gabriele
schweidj
March 26, 2020, 10:19am
4
yes Nethserver has a FDQN with a valid letsencrypt cert.
The timezone was wrong but after adjusting the timezone the problem still persists…
schweidj
March 26, 2020, 10:20am
5
I removed the account and added it again after adjusting the timezone and with only contacts and calendar.
Still the same problem…
schweidj
March 26, 2020, 8:26pm
6
also strange: Now when I check the webtop settings
„ActiveSync=enabled“ is not present in the settings anymore.
Even after „config setprop webtop ActiveSync enabled“ and „ signal-event nethserver-webtop5-update„
it is not shown in the settings…
lucag
(Luca Gasparini)
March 29, 2020, 7:02pm
7
Hi @schweidj ,
evidently the nethserver-webtop5 package was not updated before
The prop that allowed you to disable ActiveSync has already been removed from several versions, it is now always enabled.
You just have to pay attention to this: WebTop 5 — NethServer 7 Final
schweidj
March 31, 2020, 10:34am
8
Hi @lucag
thank you Luca. I was Aware of the webtop-sogo conflict.
I tried adding a contact and an event today and it synced successfully at once.
I don´t know why. Maybe I just had to wait some time after changing the timezone….
Thanks also @pike for the timezone hint
pike
(Michael Kicks)
March 31, 2020, 10:39am
9
Once is not enough! Try a to do more edits/adds into contacts and calendar.
schweidj
March 31, 2020, 1:28pm
10
Hi @pike
you are right, second try, same Problem. No sync….
pike
(Michael Kicks)
March 31, 2020, 1:34pm
11
I’ll wait your feedback tomorrow too, with some other tests
