Webtop admin not accepted
NethServer Version: 7.9
Module: Webtop5
rpm -qa *webtop*
webtop5-webdav-0.3.0-1.ns7.noarch
nethserver-webtop5-1.7.8-1.ns7.noarch
webtop5-zpush-1.2.1-1.ns7.noarch
webtop5-1.4.24-1.ns7.noarch
I am using NS with AD. All credentials work fine, but not the (domain) admin user in Webtop.
When I try to access to Webtop, an error occurs: `Authentication failed. Please try again’.
  1. Admin is granted access to Cockpit, Nextcloud, DokuWiki - but not to Webtop
  2. all other users get access to Webtop
What has happened here?
Best regards, Marko
If the username is admin it didn’t work, because there is an admin-user in webtop itself.
if you try to login with admin to webtop it chooses the weptop admin with it’s password.
If you didn’t change, the password is admin
https://docs.nethserver.org/en/v7/webtop5.html#admin-user
Thank you for the advice.
I had to use admin@mydomain.tld
Sincerely, Marko
I’m glad to hear, that it works now. Could you please mark the topic as solved?
