Hello there,
im currently working the first time with Nethserver and my goal ist to create a Mail-Server as alternative to a Microsoft Solution. I already managed to run SOGo with Nethserver and Outlook. So now i wanted to check Webtop but im already running into a problem that when i log in with a user into the webinterface over firefox the buttons wont work. IE runs fine Chrome is not checked yet by me. Am I the only one with that problem? already emptied the cache and addins/ons are not installed in firefox.
I’ve issues with FF 63.0.1 (64-bit) on Fedora with webtop5-1.2.8-1.ns7.noarch
I report that with any component (mail, calendar, activity) a popup frame might appear white (usually not just after login but after a while). See the screenshot:
FF 63.0.3 64-Bit on Windows 10 Could try it on a virtual client to see if the buttons dont work there too. Any other things what could disable the buttons in FF but not IE on the Client PC?
Edit: test on virtual windows 10 with FF 63.0.3 64- and 32-bit: buttons are working. Seems to be a problem with my client PC
Safe mode didnt work and cant reinstall firefox or install java cause its a work pc and im only an intern ill live with the mystery and keep working with firefox over the virtual client .
thanks for the help
