Webserver vhost gets a 404 (need testers)
Hello I fixed a bug for the first vhost creation, you previously got a 404 until we drop files by sftpgo or with any other sftp clients
now when you create the vhost and you reach it by your browser you get a 403 (authentication failed) or if you enable the Root directory file listings you can see the list of your files inside your virtualhost
this bug is not a nasty one, every kind of testers are welcome, please follow up the QA
Tested on Rocky and it worked as expected.
released as 1.0.17
thank you very much
