Well that is life , I have a machine with this and that HW âŠ
I put NS on the disk one SSD âŠ
and my data on a huge HDD âŠ
this is the principle of modern computers and ⊠servers
If a software cannot handle that , then it has problem that is called : Limitation .
I may sound picky, but this limitation should be known.
Web servers administrators have already their protocols and standards,
so âyouâ land in his office with a folder like:
/home/webserver1/.local/share/containers/storage/volumes/websites/_data/900X
he will not be happy, so
Or we can modify that ( a parameter somewhere)
Or we do the soft links tricks,
a process accesses a file, the OS takes care of the rest (the file can be a device, a regular file, a link âŠ)
security wise, I donât see the relationship ⊠I mean, we have web-servers running âdifferentlyâ than this everywhere âŠjust fine .
logically there a solution to this in here (NS8).
the further I went is with www-data as the âuserâ , later on I will redo everything with âwebserver1â as the user, as I suspect a read permission issue somewhere âŠ
unless the container runs under a different (U)ID .
another question,
the folders in _data , 900X ⊠, have UID and GID foreing to the server, so I deduct from what you said that , those UID/GID are local in the containers ?
exp: username âtotoâ has UID of 12134 , on the server that UID doesnt exist and yet has been created by NS8âs webserver installer .
also, I may just zap everything by just mounting the disk on _data folder ? or maybe higher in the tree ?
