Hello Mates
webserver gets its dependencies updated, nginx, sftpgo, php-fpm, I would like some tests and insight of brave testers/developers
Please ask for any questions, direct install and upgrade cases are welcome
Hello Mates
Salut @stephdl
I will test this over the new year. What do I need to enable, that this test shows up?
My Home NS8 Cluster on Proxmox is waiting…
This would be a fresh install, I will attempt an update on a client, but since the test repos do not show up, I need to enable “something”… ![]()
I put the command to upgrade from the CLI in the github issue
api-cli run update-module --data '{"module_url":"ghcr.io/nethserver/webserver:1.0.21-dev.1","instances":["webserver1"],"force":true}'
