Webconsole on NS8 in next future?
Dear @alefattorini any chance to have a webconsole on NS8 in next future?
In order to debugging a fail incoming call or something similar i dont have any tools… For a potential banality we’ll be forced to open a new ticket to have support :sweat:
thanks a lot!
Hello sir, what do you mean by a web console for NS8.
NS8 already has a web console. Unless you mean terminal.
Equally you can get proper logs for the system.
The webconsole is not still planned.
If you need such a feature, feel free to install Cockpit
Hi Giacomo, we have a NS8 SaaS. Are we able to install Cockpit by ourselves
I’m not sure, maybe the support can install it for you.
You should open a ticket an explain your requirements, we will try to find a good solution!
