Hi Folks
Does Nethserver have the ability to log all web activity in a granular fashion - i.e. user/time/URL etc. It seems likely to me that this info is available to the system but ive not been able to locate a method of recording/accessing this data… hopefully an easy one for you big brothers out there!
Cheers
Alex
The authenticated web proxy should fit your needs.
http://docs.nethserver.org/en/v7/web_proxy.html#authenticated-mode
A HTML report is available:
thank you Markus i will give that a go
