A requirement that always ask us is to block social networks for a group of people and not others.
I’m using NS 6.8.
I follow this instruction:
Continuing the discussion from Do you use transparent proxy, and if so how?:
But we need to use Transparent with SSL instead Transparent mode
and the faceebook was blocked
We hace problem to acces web.whatsapp, any idea how to solve this blockade?
If I understand correctly, if you use the transparent mode should I install the certificate on each machine, no way to do it automatically?
Or should I install the certificate if I enable HTTP and HTTPS ports Block
Thanks and sorry for so many questions
Regards,
aguerra
jgjimenezs
(Jose G Jimenez S )
2
for the installation of certificates you can use the address from your browser:
http://your_ip_ns/proxy.crt or https://your_ip_ns/proxy.crt
Thank you … I did like the manual says
giacomo
(Giacomo Sanchietti)
4
Maybe you can do something with AD group policies, but I don’t really know.
Sorry, but not all websites work correctly in transparent mode.
jgjimenezs
(Jose G Jimenez S )
5
@Alejandro_Guerra We recommend better to use the authenticated mode
How i can enable those ports 5222-5223 # whatsapp … temporary Just to ckeck. …If it works leave it permanent?
jgjimenezs
(Jose G Jimenez S )
7
You must create a rule in the firewall, and add objects first service in the firewall.
Regards
