I want to re-open this issue. I am not completely convinced what I noticed is the same problem.
Base install:
NethServer 7RC3
installed modules:
Samba4 DC
Fileserver
Basic Firewall
Samba4 DC provider is configured and I created several users, both as Domain Users and Domain admins. I created several shares and put in data.
With this base install I can connect to the shares using both samba-client and with Nautilus using the credentials of the created users.
Now if I install the web-proxy module I can not connect to a share with Nautilus anymore. I can connect with samba-client (I get a smb:/> prompt) but when I do an ls, I get a access denied.
It looks like web-proxy is ‘interfering’ with the samba fileserver or account provider module.
When I de-install the web-proxy module and restart the server, the shares are accessible normal again. Same goes for web-filter module which also installs squid.
Anyone care to check if this is default behavior or only with my setup?
I can reproduce it too.
The problem is winbind is started when proxy is enabled. This is the systemd unit which causes the error: /usr/lib/systemd/system/squid.service.wants/winbind.service
I guess it’s something to make squid work with Windows integrated authentication and I have no idea if it’s still needed. @davidep is only one who can shed some light on this
Edit: @robb you can fix your installation with these commands:
The NTLM authentication method is no longer supported because NethServer 7 does not run winbind due to upstream default Samba configuration, which relies on sssd-idmap.
I just applied the patch. I can confirm that with web-proxy and web-filter installed, after a server restart, i can connect to a file share with Nautilus from an Ubuntu 16.04 machine.
I tested the patch yesterday, since then Samba works with Squid.
However, now the phenomenon occurs that I can not log in the Nextcloud, all user names / passwords are declared as wrong.
I have already made the following steps to the error limit:
Patch uninstalled (yum -enablerepo = nethserver-testing remove nethserver-squid-1.5.1-1.3.g2f509d3.s7.noarch)
