Web interface not started
After restart the server, do not start the web interface. how to run it? Internet is available from the server, and the local network is not.
It may be a firewall problem.
Type:
shorewall disable
on the console. If you can access the web ui, fix your network configuration.
If only the web ui is not working, please check its service status:
systemctl status httpd-admin
Thanks, for some reason shorewall was not running.
shorewall disable
ERROR: shorewall is not running
I executed
#shorewall start
and web interface earned
I checked, and after the next reboot shorewall does not start again.
What is the best it fixed a?
You need to discover why shorewall doesn’t start at boot. Someone is already investigating a similar issue:
Thank you, it seems that the problem is really in fail2ban
