Hi everyone, I just made the update proposed by the system but after the reboot the web interface is no longer accessible.
I restarted the server using the previous kernel (not the latest installed from the upgrade) and everything works fine.
Is it possible to fix the problem and use the latest kernel, or is it better to wait for the next system update?
thank you!
luca
mrmarkuz
(Markus Neuberger)
September 16, 2017, 1:05pm
2
Hi @luca_aguzzoli ,
if you don’t use Samba shared folders then updating should be no problem.
There is a fix for using the latest kernel, check these threads:
Before update please read carefully the full announcement.
CentOS 7.4 is out with a major rebase of most of RPMs.
See upstream release notes: https://wiki.centos.org/Manuals/ReleaseNotes/CentOS7
The list of known issues is quite long this time.
Upgrade and rescue
This procedure applies to any NethServer 7.3 installation, even downgraded or broken ones.
Just execute:
yum --enablerepo=nethforge update
Then, be sure to have installed patched sssd-libwclient:
Execute:
rpm -q sssd-libwclient…
NethServer Version: 7.3
Module: server-manager
Some time after reboot getting read-only filesystem with two different (testing) virtual machines.
VM server with openldap account provider
Updating to CentOS 7.4 (some expected warnings):
warning: /etc/nsswitch.conf created as /etc/nsswitch.conf.rpmnew
warning: /etc/dnsmasq.conf created as /etc/dnsmasq.conf.rpmnew
Warning: slapd.service changed on disk. Run 'systemctl daemon-reload' to reload units.
warning: /etc/ssh/sshd_config created as /e…
Hi Markus, the fix worked for me!
thanks a lot!
Luca
mrmarkuz
(Markus Neuberger)
September 16, 2017, 1:40pm
4
luca_aguzzoli:
thanks a lot!
You’re welcome. If the problem is solved for you, please mark the topic as solved:
Now we have an amazing feature on our community platform which helps to mark a topic as SOLVED
As the OP (topic creator) you will have a button that allows you to accept an answer
[image]
Accepted answers are highlighted in the topic list:
[image]
Accepted answers are highlighted on the initial topic:
[image]
This kind of action is enabled only for topic into the Support category
Happy support!
