Hi, I’ve updated from rc2 to rc3 and web traffic is only filtered in “Transparent mode”, all web traffic is allowed in manually configuration. I’ve tested blocking all web traffic (web filtering options) but is the same problem.
I’ve installed rc3 using the last ISO available (clean installation) and it’s the same problem.
I can confirm this issue. In Manual mode i can access blocked websites even if I didn’t specified the web proxy server in Firefox configuration.
Cheers.
I can’t reproduce your problem, sorry.
Did you check “Block HTTP and HTTPS ports” on the proxy page?
Please, check if you can spot any error in /var/ufdbguard/logs/ufdbguardd.log.
I have not checked “Block HTTP and HTTPS ports” on the poxy page, because all web traffic is allowed in manually proxy configuration. In transparent mode filtering is working.
I have found this in the log:
NS rc3 updated from rc2
2016-12-22 14:54:22 [2766] loading URL category defaulttable with creation date 20161222.1624
2016-12-22 14:54:22 [2766] loading URL table from "/var/squidGuard/blacklists/automobile/boats/domains"
2016-12-22 14:54:22 [2766] loading URL table from "/var/squidGuard/blacklists/news/domains"
2016-12-22 14:54:22 [2766] loading URL table from "/var/squidGuard/blacklists/isp/domains"
2016-12-22 14:54:22 [2766] FATAL ERROR: line 293: "aggressive" is a keyword and must be surrounded by quotes in configuration file /etc/ufdbguard/ufdbGuard.conf *****
2016-12-22 14:54:22 [2766] A FATAL ERROR OCCURRED: all requests are answered with "OK" (see previous lines with "FATAL ERROR" for more details) *****
2016-12-22 14:54:22 [2766] configuration on host fnd-proxy-cloud.fundacion-jala.local: -------------------------------------------
2016-12-22 14:54:22 [2766] dbhome "/var/squidGuard/blacklists"
2016-12-22 14:54:22 [2766] logdir "/var/ufdbguard/logs"
2016-12-22 14:54:22 [2766] # default: pidfile "/var/run/ufdbguard/ufdbguardd.pid"
2016-12-22 14:54:22 [2766] port 3977
2016-12-22 14:54:22 [2766] # interface "all"
2016-12-22 14:54:22 [2766] # default: email-server "none"
2016-12-22 14:54:22 [2766] # default: my-hostname "none"
2016-12-22 14:54:22 [2766] # default: admin-email "none"
2016-12-22 14:54:22 [2766] # default: sender-email "none"
2016-12-22 14:54:22 [2766] # default: external-status-command "none"
2016-12-22 14:54:22 [2766] logpass off
2016-12-22 14:54:22 [2766] logblock on
2016-12-22 14:54:22 [2766] logall off
2016-12-22 14:54:22 [2766] upload-crash-reports off
2016-12-22 14:54:22 [2766] lookup-reverse-ip off
2016-12-22 14:54:22 [2766] use-ipv6-on-wan on
2016-12-22 14:54:22 [2766] num-worker-threads 68
2016-12-22 14:54:22 [2766] squid-version "3.5"
2016-12-22 14:54:22 [2766] squid-uses-active-bumping off
NS rc3 - Clean Installation (I’ve used the last ISO available)
2016-12-23 03:24:17 [27540] loading URL category defaulttable with creation date 20161223.0724
2016-12-23 03:24:17 [27540] loading URL table from "/var/squidGuard/blacklists/finance/banking/domains"
2016-12-23 03:24:17 [27540] loading URL table from "/var/squidGuard/blacklists/automobile/boats/domains"
2016-12-23 03:24:17 [27540] loading URL table from "/var/squidGuard/blacklists/news/domains"
2016-12-23 03:24:17 [27540] loading URL table from "/var/squidGuard/blacklists/isp/domains"
2016-12-23 03:24:17 [27540] FATAL ERROR: line 293: "aggressive" is a keyword and must be surrounded by quotes in configuration file /etc/ufdbguard/ufdbGuard.conf *****
2016-12-23 03:24:17 [27540] A FATAL ERROR OCCURRED: all requests are answered with "OK" (see previous lines with "FATAL ERROR" for more details) *****
2016-12-23 03:24:17 [27540] configuration on host proxyfnd.fundacion-jala.local: -------------------------------------------
2016-12-23 03:24:17 [27540] dbhome "/var/squidGuard/blacklists"
2016-12-23 03:24:17 [27540] logdir "/var/ufdbguard/logs"
2016-12-23 03:24:17 [27540] # default: pidfile "/var/run/ufdbguard/ufdbguardd.pid"
2016-12-23 03:24:17 [27540] port 3977
2016-12-23 03:24:17 [27540] # interface "all"
2016-12-23 03:24:17 [27540] # default: email-server "none"
2016-12-23 03:24:17 [27540] # default: my-hostname "none"
2016-12-23 03:24:17 [27540] # default: admin-email "none"
2016-12-23 03:24:17 [27540] # default: sender-email "none"
2016-12-23 03:24:17 [27540] # default: external-status-command "none"
2016-12-23 03:24:17 [27540] logpass off
2016-12-23 03:24:17 [27540] logblock on
2016-12-23 03:24:17 [27540] logall off
2016-12-23 03:24:17 [27540] upload-crash-reports off
2016-12-23 03:24:17 [27540] lookup-reverse-ip off
2016-12-23 03:24:17 [27540] use-ipv6-on-wan on
2016-12-23 03:24:17 [27540] num-worker-threads 68
2016-12-23 03:24:17 [27540] squid-version "3.5"
2016-12-23 03:24:17 [27540] squid-uses-active-bumping off
2016-12-23 03:24:17 [27540] redirect-https "192.168.10.1:443" # NO bumping (may splice)
2016-12-23 03:24:17 [27540] redirect-bumped-https "https://blockedhttps.urlfilterdb.com/cgi-bin/URLblocked.cgi?clientgroup=%s&category=%t&url=%u" # active bumping
I’ve modified the file: # vi /etc/ufdbguard/ufdbGuard.conf and changed !aggressive for '!“aggressive”
Note: If I select other category using the Web console the problem comeback, in order to fix it you should edit the file and restart the service again.
@rlndmrnda I already fixed the problem, but the update has not been released.
Please, install the new package from our testing repository: yum --enablerepo=nethserver-testing update nethserver-squidguard
