Web Content Filter & AD users and groups
NethServer Version: NethServer release 7.7.1908 (final)
Module: Web Content Filter
I’m doing my first steps with Nethserver. I’ve installed AD, Firewall and proxy and Web Content Filter. I’m using Transparent with SSL proxy.
Everything works well if I use profiles related to Firewall objects, but when I want to set filters related to Active Directory groups or users the filter does not apply.
How is it possible? I think everything is correctly configured since otherwise, it would not work well with firewall objects.
I’ve checked the “Block HTTP and HTTPS ports” option.
Thank you !
Hi, first welcome to the community.
To your question,
could you post some files please. squid and ufdbguard config
/etc/squid/squid.conf
/etc/ufdbguard/ufdbGuard.conf
and log files at the time you try to open a site which should be blocked, but isn’t blocked.
/var/log/squid/access.log
/var/log/ufdbguard/ufdbguard.log
Michael
You need to use authenticated proxy instead of transparent one to get the user/group information. Then users/groups are selectable in the Profile creation wizard.
https://docs.nethserver.org/en/v7/web_proxy.html#authenticated-mode
Hi @mrmarkuz,
first of all thank you for your answer. I changed the proxy to the authenticated one, and when I try to navigate any page, the browser asks me for a username and password. I try the user AD credentials and the browser asks again for the user and password.
access.log:
1583920447.324 2 192.168.0.126 TCP_DENIED/407 4223 CONNECT accounts.google.com:443 - HIER_NONE/- text/html
The user is authenticated properly to AD and has been successfully linked to the domain.
Any Idea?
Hi @m.traeumner and thank you for your answer,
I was using Transparent Proxy, now I’m checking the authenticated proxy as I replied the other post.
Do you think it is not possible to work with AD users with a transparent proxy?
Thank you!
@mrmarkuz is right here, I didn’t think about it. A little description why it doesn’t work is here:
@mrmarkuz Any idea here?
@hortiz, please check /var/log/squid/cache.log for errors.
Which OS/browser do you use? Did you try another browser?
All Windows clients must access the proxy server using the FQDN.
Another thread about auth proxy with AD:
I think
could also give some hints.
hello
In yourś client set proxy with hostname not ip address.
Sorry my english is bad.
Welcome to the community @Leonardo_Lovera.
No problem, we can understand you and most of us aren’t English native speaker.
