Weak Password to users
Hello,
I want weak passwords to users in my network, but i can’t change. Only strong passwords are possible.
I have installed the nethserver-password module and I changed the setting to none (config setprop passwordstrength Users none).
I confirmed the current policy to None (config getprop passwordstrength Users).
Can someone help me?
Regards,
Marcelo Costa
I think it’s best to leave them in secure passwords
Did you do which suggests here? Users and groups — NethServer 7 Final
try edit in this path: /etc/e-smith/db/configuration/defaults/passwordstrength @marceloeng
regards
it means only that the only password length check is done… password can’t be shorter than 7 (IIRC) chars
if it doesn’t work as expected, you’d report it as a bug
finally, using weak passwords, even if in local network is not a smart idea.
I want a weak password to non-admin users.
I know about the security, but my users are familiarized with a weak password.
I still can’t change to a weak password.
Thanks for help,
Marcelo
you already had the answer: with policy None, you can use whatever password you prefer, as long as it’s at least 7 chars long… it’s not a NS “problem”, it’s an os (IIRC) feature.
sorry but, this is a no problem… you are the one who admins the server… you have to give rules, they have to adhere… you should never transform an human approach problem (lazyness) into a technical one.
Thanks Stefano,
I understand and agree with your position. I will try to maintain a policy of strong passwords.
Regards,
Marcelo
