I got a warning updating today.
The server is on the stable release (I can’t find the entry “Software center | Configure” anymore)
warning: /etc/yum.repos.d/NsReleaseLock.repo saved as /etc/yum.repos.d NsReleaseLock.repo.rpmsave
ls shows:
# ls /etc/yum.repos.d/NsReleaseLock.repo* -l
-rw-r--r-- 1 root root 1223 Dec 13 04:00 /etc/yum.repos.d/NsReleaseLock.repo.rpmnew
-rw-r--r-- 1 root root 1160 Jun 6 2018 /etc/yum.repos.d/NsReleaseLock.repo.rpmsave
This is the record of screen, I need to do something after the update?:
# yum update
epel/x86_64/metalink | 15 kB 00:00:00
* ce-base: centos.eecs.wsu.edu
* ce-extras: centos.eecs.wsu.edu
* ce-updates: centos.eecs.wsu.edu
* epel: mirror.sjc02.svwh.net
* nethforge: mirror.framassa.org
* nethserver-base: mirror.framassa.org
* nethserver-updates: mirror.framassa.org
centos-sclo-rh | 3.0 kB 00:00:00
centos-sclo-sclo | 2.9 kB 00:00:00
epel | 4.7 kB 00:00:00
(1/2): epel/x86_64/updateinfo | 959 kB 00:00:07
(2/2): epel/x86_64/primary_db | 6.6 MB 00:00:40
Resolving Dependencies
--> Running transaction check
---> Package nethserver-base.noarch 0:3.6.2-1.ns7 will be updated
---> Package nethserver-base.noarch 0:3.7.0-1.ns7 will be an update
---> Package nethserver-lang-en.noarch 0:1.2.18-1.ns7 will be updated
---> Package nethserver-lang-en.noarch 0:1.2.19-1.ns7 will be an update
---> Package nethserver-lib.noarch 0:2.2.9-1.ns7 will be updated
---> Package nethserver-lib.noarch 0:2.2.10-1.ns7 will be an update
---> Package nethserver-release.noarch 0:7-12.ns7 will be updated
---> Package nethserver-release.noarch 0:7-13.ns7 will be an update
---> Package systemd.x86_64 0:219-62.el7_6.3 will be updated
---> Package systemd.x86_64 0:219-62.el7_6.5 will be an update
---> Package systemd-libs.x86_64 0:219-62.el7_6.3 will be updated
---> Package systemd-libs.x86_64 0:219-62.el7_6.5 will be an update
---> Package systemd-sysv.x86_64 0:219-62.el7_6.3 will be updated
---> Package systemd-sysv.x86_64 0:219-62.el7_6.5 will be an update
Dependencies Resolved
Package Arch Version Repository Size
Updating:
nethserver-base noarch 3.7.0-1.ns7 nethserver-updates 246 k
nethserver-lang-en noarch 1.2.19-1.ns7 nethserver-updates 24 k
nethserver-lib noarch 2.2.10-1.ns7 nethserver-updates 98 k
nethserver-release noarch 7-13.ns7 nethserver-updates 25 k
systemd x86_64 219-62.el7_6.5 ce-updates 5.1 M
systemd-libs x86_64 219-62.el7_6.5 ce-updates 407 k
systemd-sysv x86_64 219-62.el7_6.5 ce-updates 84 k
Transaction Summary
Upgrade 7 Packages
Total size: 5.9 M
Is this ok [y/d/N]: y
Downloading packages:
Running transaction test
Transaction test succeeded
Running transaction
Updating : systemd-libs-219-62.el7_6.5.x86_64 1/14
Updating : systemd-219-62.el7_6.5.x86_64 2/14
Updating : nethserver-lib-2.2.10-1.ns7.noarch 3/14
Updating : nethserver-base-3.7.0-1.ns7.noarch 4/14
Updating : systemd-sysv-219-62.el7_6.5.x86_64 5/14
Updating : nethserver-release-7-13.ns7.noarch 6/14
Updating : nethserver-lang-en-1.2.19-1.ns7.noarch 7/14
Cleanup : nethserver-base-3.6.2-1.ns7.noarch 8/14
Cleanup : systemd-sysv-219-62.el7_6.3.x86_64 9/14
Cleanup : nethserver-lib-2.2.9-1.ns7.noarch 10/14
Cleanup : nethserver-release-7-12.ns7.noarch 11/14
warning: /etc/yum.repos.d/NsReleaseLock.repo saved as /etc/yum.repos.d/NsReleaseLock.repo.rpmsave
Cleanup : nethserver-lang-en-1.2.18-1.ns7.noarch 12/14
Cleanup : systemd-219-62.el7_6.3.x86_64 13/14
Cleanup : systemd-libs-219-62.el7_6.3.x86_64 14/14
Verifying : nethserver-lang-en-1.2.19-1.ns7.noarch 1/14
Verifying : systemd-219-62.el7_6.5.x86_64 2/14
Verifying : nethserver-release-7-13.ns7.noarch 3/14
Verifying : nethserver-lib-2.2.10-1.ns7.noarch 4/14
Verifying : nethserver-base-3.7.0-1.ns7.noarch 5/14
Verifying : systemd-libs-219-62.el7_6.5.x86_64 6/14
Verifying : systemd-sysv-219-62.el7_6.5.x86_64 7/14
Verifying : nethserver-lang-en-1.2.18-1.ns7.noarch 8/14
Verifying : nethserver-lib-2.2.9-1.ns7.noarch 9/14
Verifying : nethserver-release-7-12.ns7.noarch 10/14
Verifying : systemd-219-62.el7_6.3.x86_64 11/14
Verifying : systemd-sysv-219-62.el7_6.3.x86_64 12/14
Verifying : nethserver-base-3.6.2-1.ns7.noarch 13/14
Verifying : systemd-libs-219-62.el7_6.3.x86_64 14/14
Updated:
nethserver-base.noarch 0:3.7.0-1.ns7 nethserver-lang-en.noarch 0:1.2.19-1.ns7
nethserver-lib.noarch 0:2.2.10-1.ns7 nethserver-release.noarch 0:7-13.ns7
systemd.x86_64 0:219-62.el7_6.5 systemd-libs.x86_64 0:219-62.el7_6.5
Complete!
]# less /etc/yum.repos.d/NsReleaseLock.repo.rpm
NsReleaseLock.repo.rpmnew NsReleaseLock.repo.rpmsave
]# less /etc/yum.repos.d/NsReleaseLock.re/etc/yum.repos.d/NsReleaseLock.repo.rpmsave
4,5c4
< # This configuration is active only when the sysconfig/NsReleaseLock prop
< # is 'enabled'.
> # This configuration is active only when sysconfig[NsRelease] is 'enabled'.
21d19
< repo_gpgcheck=1
23c21
< enabled = 0
> enabled = 1
30d27
< repo_gpgcheck=1
32c29
< enabled = 0
> enabled = 1
39d35
< repo_gpgcheck=1
41c37
< enabled = 0
> enabled = 1
Regards
