I am testing nethserver
I wonder if I can have an array with multiple branches being interconnected
example
Headquarters 192.168.1.x
branches 192.168.2.x
branches 192.168.3.x
Someone has to how?
Thank you
example
Someone has to how?
Thank you
Hi so mini how to @willaraujo
1 First Open Configuration -> VPN select OpenVPN Tab
2 Enable roadwarrior check RoutedMode and enter IP 10.10.10.0 NetMask 255.255.255.0 Enable LZO and in Advance option Change Port from default
3 Return to Accounts Tab
4 Push CreateNew like Office1 and Input Remote Network 192.168.2.0 255.255.255.0
5 Push CreateNew like Office2 and Input Remote Network 192.168.3.0 255.255.255.0
6 Install OpenVPN on your Remote Offices and from Accounts tab Download Configuration for your Offices
7 Rename .ovpn to .conf end put it in /etc/openvpn on your remote Office GW and restart openvpn
8 Your Offices now interconnected!
Thank you for your answer
Sorry,
This configuration would work with Nethserver the branch, connecting the headquarters?
Nethserver - Headquarter - 192.168.1.x (or have to change the IP for 10.0.0.x?)
Nethserver - Branch 1 - with workstations - 192.168.2.x
Nethserver - Branch 2 - with workstations - 192.168.3.x
thanks
10.10.10.0 it is only for VPN LAN , Headquarter - 192.168.1.1 it is on your geen LAN
