I followed the instruction from @Nas and installed the certificate on my computer. [Howto configure OpenVPN…][1]
When I try the VPN connection I got the error message
As fare I understand the VPN request is forward to the NS on the RED connection but on this side is no DHCP who know this FQDC to resolve.
I can’t find any option to create the certificate with the IP address instead with the FQDN.
How can I solve this problem?
[1]: Howto configure OpenVPN Roadwarrior
This only works if you have a static external IP on your RED interface.
If you have a modem/router between your NS and internet, then put the external IP of your router there. If your privider sets you up with a dynamic IP adress, you will have to use a service like noip or other dyndns service.
@EddieA firstly I suppose we have an issue with NATed external IP, another issue most probably related to connection to the provided server IP.
All variants should be checked.
I found one mistake. I copied the configuration file *.ovpn in /Progrm Files(x86)/OpenVPN/config/ but it doesn’t use it.
I started a connection with right click “Start OpneVPN connection on this config file” and I got one but still an error.
