VOIP not working behind NethServer
Hi Team,
I am trying to configure the Nethserver to allow voip. we are using x-lite application but it is not working. It is working on our existing setup and I want to make this work on Nethserver. Please see image below of the error message:
Is there any configuration on the firewall that I needed to make it work? Thank you.
Regard,
Eliezer Ga
Check this:
Thank you dor this. What tools I will use to edit the line?
Terminal editors like Vim, Vi, Emacs, Nano or WinSCP :smile:
I will check on this. Thank you so much
It works perfectly. Thank you so much
Good! Can you please mark this topic as resolved?
