NethServer Version: 7.9.2009
** Guacamole:0.0.1
Hello!
I’m trying to configure the VNC connection from Guacamole to desktop computers. Windows computers works fine, but I’m unable to connect to MAC computers (2 different mac books). When I connect to the MAC computer, I’m get “you have been disconnected” and “/var/log/messages” shows the following error:
Mar 3 15:15:52 server Selected Security Scheme 30
Mar 3 15:15:52 server guacd[9941]: Libgcrypt warning: missing initialization - please fix the application
Mar 3 15:15:52 server kernel: guacd[9946]: segfault at 0 ip 00007f16c03ac944 sp 00007f16b30ee990 error 4 in libvncclient.so.0.0.0[7f16c0398000+1d000]
Mar 3 15:15:52 server guacd[1137]: Connection "$620c5a74-8986-48cb-a3d8-bb518074aeb5" removed.
Mar 3 15:15:52 server guacd: guacd[1137]: INFO:#011Connection "$620c5a74-8986-48cb-a3d8-bb518074aeb5" removed.
Mar 3 15:15:56 server server: 15:15:56.552 [Thread-94] INFO o.a.g.tunnel.TunnelRequestService - User "arturs" disconnected from connection "19". Duration: 4886 milliseconds
Could you please help to troubleshoot this?
Thanks!
I’ve been using Guacamole for a doctor’s practice for over a year (To a VNC enabled Mac) - and it’s worked sofar.
I just checked it, and I get the same errors you are, so it’s probably an issue after an update…
The Mac is the PACS for X-Ray stuff…
Now to see what exactly “broke” Guacamole…
@mrmarkuz: Hi Markus any ideas?
My Client has a Disk Issue, so updating Guacamole has to wait til Friday, when we get replacements…
Thanks. I have looked at workaround posted and seen that the paths listed on the comments did not work in Nethserver case. So we need to wait the next release. Is it correct?
Hello!
I have already this version on server. After execution of the command the connection to MAC does not work and Libgcrypt warning is logged on messages log.
The RPMs do not cover all Guacamole versions. You may just download one of the versions here.
Only the guacamole-*-.war file is needed, rename it to guacamole.war and put it to /var/lib/guacamole/ and restart the needed services with
signal-event nethserver-guacamole-update
As regards the guacd VNC component, I found packages with older versions here.
Hello!
I have moved the 1.20 war file to the /var/lib/guacamole folder and restarted the service. Nothing has been changed- the same (error is generated).
