Vlans Over IPSEC tunnel
NethServer Version: ns8
Module: vpn ipsec
Hi i’ve setup a ipsec tunnel thru 1 nethsecurity 8 and another none nethsecurity fw and it’s working but i cannot ping or reach vlans from ns8 configured on the second firewall - i cannot understand why
any ideas?
thanks!
Good morning,
The vlan information would be stripped from the tunnel, so it wouldn’t work.
When you say you can’t understand, is this because you have done it in the past and it has worked for you?
Some routers such as Mikrotik would allow you to do EoIP and then you can pass the VLAN.
Or US20100228974A1 - VLAN TAGGING OVER IPSec TUNNELS - Google Patents
Best regards,
