Is there a way to get the VLANs to show up as interface options in the Security section so I can apply different lists and application blocking based off the VLAN?
The only option that shows up for me is LAN, which then applies everything to everything associated with LAN and the VLANS.
As regards Threat shield DNS, it could be possible by creating a zone, for example VLAN1 and include the VLAN interface, see also Zones and policies — NethSecurity documentation
Then the new zone shows up in Threat shield DNS settings so it should be possible to enable threat shield DNS for example for LAN but not for VLAN.
The issue is that NethSecurity currently uses only a single dnsmasq instance, which is configured via:
/etc/config/dhcp: option confdir '/tmp/dnsmasq.d'
This instance is managed and populated by ThreadShield DNS for filtering purposes.
Suggested Solution:
Set up two separate dnsmasq instances:
Filtered instance (e.g. port 53000):
This instance uses DNS filtering (via ThreadShield).
You can create a port forwarding rule that redirects incoming DNS traffic (port 53) from specific zones or interfaces to port 53000 on lo, for clients that should be filtered.
Unfiltered instance (default, port 53):
This instance runs without any filtering and serves clients that should bypass ThreadShield.
Example:
dnsmasq.0 → port 53000, filtered
dnsmasq.1 → port 53, unfiltered (default)
Configure firewall NAT/redirect rules to selectively forward DNS traffic to the desired instance based on zone/interface/client.
This setup would allow granular control over which devices or networks use filtered vs. unfiltered DNS.
