Virtual HostNAme (FQDN) not tested in Virtualhosts Panel
I don’t know if it is a feature, or a bug, but hostname (ServerNames property) can be set even if they are not real (FQDN) hostname in the virtualhosts panel.
Of course there are some validators in /usr/share/nethesis/NethServer/Template/VirtualHosts/Modify.php but they don’t work.
My php is a bit rusted :slight_smile:
Sorry but I don’t understand :frowning:
Can you provide an example?
In the virtualhosts panel you ask to set a fqdn domain name and i can write a bad domain name like ‘toto’
Got it, thank you!
It seems that the interface is accepting hostname, not FQDN.
From apache 2.4, even a hostname (not FQDN) should be valid:
https://httpd.apache.org/docs/2.4/mod/core.html#servername
This is the relevant part in Web UI:
This topic was automatically closed 24 hours after the last reply. New replies are no longer allowed.
